I am thinking about purchasing a USB2.0 external hard drive to back up all my media. Anyone have any tips and/o product suggestions? My machine is a laptop with USB2.0, Firewire and RJ45 connections.
If you have Firewire I/O on your laptop, I would definitely suggest a external Firewire drive. It just has less problems with data transfers, especially large video files than does USB. A good compromise that I use is a external drive with both Firewire and USB 2.0. That gives you more options for just a small increase in price.
I recently bought a very high quality Apricorn EZ-BUS-DTC-KIT Combo USB/Firewire Backup & External Storage Enclosure that included some nice backup software (e.g. can back up entire drives and create boot disks) . I then simply dropped in a 200GB Maxtor that I had bought for $30 AR on black friday and it works great.
If you prefer, you can simply use it as an external drive (e.g. it just maps as a new drive on your system when you power it on).
Firewire is faster than USB2.0 if you have it, but USB (along with downward 1.1 compatibility) gives more flexibility.
Edit:
There is an excellent external enclosure discussion here:
http://www.fatwallet.com/t/28/496281
-BL -
Hey thanks for the replies and the link. After checking out some of the prices for an external USB/firewire drive. I am VERy tempted to purchase a new PC now
You guys are killing me!
I can be strong, I can be strong.
Ahh, my chance to really ruin someones day............
The hot setup that I have been playing with is external SATA boxes. What's not to like? Full SATA speed 150MB/S transfers. (On paper, at least) External power, so no drag on the system. Hot swappable. SATA drives are inexpensive now and the boxes are out there. You just need a PCI SATA card with a external connector or there's adapters for a PCI slot pass through connector for a regular internal card.
Just one example:
http://www.cwol.com/serial-ata/sata-drive-enclosures.htm
Compared to USB 2.0 or Firewire, this is a nice alternative. -
You sure cant beat SATA. I already own a SATA drive (200GB) inside an Enclosure which is both USB 2.0 and SATA. My MB came with a SATA bracket for connecting SATA externally. The speed is amazing and fast as my internal SATA drives.
In all of my tests, SATA was 3-4 times faster than USB 2.0
General Discussion: Some good investments for Video Authoring/Hardware
By Krelmaneck in forum Newbie / General discussionsReplies: 6Last Post: 19th May 2011, 02:25 -
Online backup: Is this a good idea?
By usta in forum ComputerReplies: 26Last Post: 21st Jul 2009, 02:02 -
What are good specs for a high-quality MP4 file? (Will look good on my 40&q
By HarlanPepper in forum Video ConversionReplies: 6Last Post: 11th Feb 2009, 03:18 -
Looking for a Good Backup HDDVD Player??
By ofield1 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 17th Mar 2008, 13:01 -
Can anyone suggest a GOOD app to backup my computer data?
By Hittz in forum ComputerReplies: 14Last Post: 4th Jul 2007, 13:37
