I have a couple of DVD's which display subtitles regardless of any remote commands. Is there a simple method of disabling the display of those subtitles in the DVD file structure?
Thanks in advance.
Hi-
While there are DVDs which have selectable subtitles that you can't turn off (that can be fixed by removing the PUOs (Prohibited User Operations)), many more have the subs burned into, or encoded onto, the video. Are you sure which you have? To test, play one of the Vobs (not the DVD, but a Vob), and check. If you see subs, then nothing can be done.
If you don't see any subs, there are several ways to fix it. Here are 2. Open the DVD in DVD Decrypter. Go Tools->Settings->File Mode, and check the 2 Remove PUOs boxes. Decrypt in File Mode and burn back to DVDR. Another is to open the already decrypted DVD (without having removed the PUOs during the decrypting stage) on the hard drive in VobBlanker and Process without doing anything else. It removes the PUOs by default. Near the top you'll see the boxes already checked.
How can I force my Video Converter to read Unicode UTF-8 subtitles?
By MoneyHoney in forum SubtitleReplies: 7Last Post: 27th Apr 2012, 19:13 -
Force FFDSHOW?
By therock003 in forum Software PlayingReplies: 6Last Post: 25th Feb 2012, 13:24 -
Force 16:9
By Giorgis in forum Authoring (DVD)Replies: 10Last Post: 4th Oct 2010, 01:50 -
How to force subtitles to be shown in certain parts of the DVD?
By dexter30 in forum SubtitleReplies: 1Last Post: 24th Jul 2009, 19:58 -
Force autoplay
By ocgw in forum Media Center PC / MediaCentersReplies: 0Last Post: 2nd Jul 2009, 18:48
