I'm new at this, but I cannot get VirtualDub or CCE 2.5 SP to accept an AVI. What do I need to do. The AVI's are from a DV cam, I tried rendering them as uncompressed AVI but still no go. I'm using XP and an Athlon 1200. CCE tries to convert the AVI but comes up with the XP and error occurred, send info to microsoft etc.
Thanks for any help.
Try StreamFab Downloader and download from Netflix, Amazon, Youtube! Or Try DVDFab and copy Blu-rays!
I have the exact same problem. I think it has something to do with the codec used to import your DV. I bypassed it by importing DV into my Ulead Mediastudio after capturing and saving it as an AVI using the Huffyuv compression. This compression is said to be lossless and I believe that (it's actually almost 2x as big as the DV captured AVI). I also resize at this point since you don't need to do that later on with Vdub or TmpGenc ... and it's better quality if you do it there.
Greets and good luck.
Virtual Dub setting help
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 10Last Post: 27th Oct 2011, 17:55 -
Virtual dub
By santolina in forum Newbie / General discussionsReplies: 4Last Post: 22nd Jul 2009, 13:48 -
Virtual Dub problem
By rocka in forum EditingReplies: 3Last Post: 2nd Jan 2009, 03:46 -
I have a virtual dub question.
By mmmipa in forum AudioReplies: 6Last Post: 12th Mar 2008, 03:34 -
help with virtual dub
By Remyisme in forum Newbie / General discussionsReplies: 7Last Post: 30th Jan 2008, 15:36
