    Dec 2005
    What Program does everyone use here ?
    Dec 2005
    i switch between dvd95copy, which i love.....clonedvd....dvd2one2...dvd decrypter....one click.....dvdfab.....
    my favorite is 95copy....if i cant get it to work on there, i will go right down the line
  3. Member Stormin Norman II's Avatar
    Dec 2005
    Michigan, United States
    Still Stormin Norman.
  4. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    DVDDecrypter and then DVDShrink and then Nero.
    If in doubt, Google it.
  5. Mod Neophyte redwudz's Avatar
    USA
    DVD Shrink.
    BTW, you will get much better responses if you use a descriptive subject title. Like, "Which DVD backup programs do you use?"
    'What Program' doesn't tell us much. And it makes it harder for others to do a forum search for your subject.
  6. Netscape 7.2
  7. Member waheed's Avatar
    Jul 2003
    Manchester, UK
    DITTO 8)
  8. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    DVDShrink/DVDDecrypter. DVDFab Decrypter for those few discs the first 2 wont handle.
    /Mats
