I am looking at recording the Oscars this year in HD to make DVDs out of them (don't ask me why; I just like recording the Oscars.)
Unfortunately the problem I ran into back in 2004 when I did it was that I used the old script that was on inmatrix.com for downconverting 720p streams to DVD. It's barely tolerable for film-based programming, but for non-24p-based video, it's absoultely unacceptable.
Instead of deleting every other frame, wouldn't it be possible to combine two frames as if they were fields and then encode at 29.97 interlaced to retain the live video look? I seem to remember that Premiere Pro might have a function for that purpose, but it doesn't load AC-3 files.
Also, I'm hoping that the answer to this might resolve the jerkiness of motion I have had with previous 720p projects, such as the upcoming season of "24" and the "Alias" finale.
Here's my current workflow:
1. Record w/FusionHDTV2 (soon to be 5 or MyHD)
2. Edit with HDTVtoMPEG2
3. Demux w/DVD2AVI
4a. Modify Inmatrix AVISynth script for the specific .d2v project
4b. Correct AC-3 sync errors in BeSweet or convert to WAV
5a. Load AVISynth script into TMPGEnc Plus 2.5 and encode w/o edits @ 852x480, 16:9, Constant VBR w/high quality (around 6000-8000Mbps, although I could drop to as low as 4500 without too bad of a quality loss)
5b. OR Add WAV file to TMPGEnc Plus 2.5 and encode w/edits
6. Remux in TMPGEnc
7. Edit in Ulead MediaStudio Pro 7 to preserve AC-3 and add transitions and titles
8. Render for DVD
9. Import into TMPGEnc DVD Author
10 Burn DVD.
If anyone can think of any shortcuts that would get more quality, please let me know...
Assuming a 16:9, progressive, 59.94 frame per second source, the following AVISynth script lines should convert it to 29.97 frame per second interlaced NTSC video:
#after opening your video file
LanczosResize(720, 480) #for 16:9 anamorphic DVD
AssumeTFF()
SeparateFields()
SelectEvery(4,0,3) #top field from first frame, bottom from second
Weave()
Feed that to your MPEG2 encoder and encode as 29.97 fps interlaced 16:9.
how to stream live tv on mobile
By funzclub in forum Video Streaming DownloadingReplies: 4Last Post: 26th Mar 2012, 13:01 -
Animation IVTC and possible light clean up of live action intro
By Anonymous344 in forum Newbie / General discussionsReplies: 4Last Post: 16th Oct 2011, 19:48 -
How to stream live mms click from one mobile to another mobile live
By rahul1971 in forum Video Streaming DownloadingReplies: 0Last Post: 19th Mar 2010, 07:14 -
Checking a live stream?
By dgrim3 in forum ProgrammingReplies: 1Last Post: 18th Nov 2009, 16:42 -
live stream bitrate
By onyx808 in forum Video Streaming DownloadingReplies: 3Last Post: 28th Jul 2009, 04:46
