I'm curious to know what my Datavideo TBC-1000 specification of 4:2:2 sampling rate means. What do those numbers stand for? And why are they important? (Assuming that they are.)
Thanks,
Ed
Here's a pretty thorough explanation for you:
http://en.wikipedia.org/wiki/YUV_4:2:2 -
Informally, it means analog composite or S-Video Y/C is split (decoded) into digital Y, U, V components. 4:2:2 means the luminance is fully sampled and the chrominance components are half sampled. Without a sample rate specified, one can expect one of the followingOriginally Posted by WyoVideo
4x or 3x subcarrier frequency (3.58MHz NTSC or 4.43MHz. PAL)
13.5MHz CCIR-601 rates (same as DV and DVD)
Historically, TBC's were first 3xfsc then 4xfsc* (14.4MHz) because it was easier to tie sample rate to multiples of the subcarrier clock. Today most chips are designed for CCIR-601 (aka D1) sample rates.
Consumer stand alone TBC boxes reprocess the signal back to analog. Then the process of decoding and sampling is repeated by the capture card. A better solution would maintain digital components in 4:1:1 (DV format) or serial 4:2:2 (SDI - SMPTE 279m) to the hard disk.
* 4fsc or 4x frequency subcarrier was the source of the 4:2:2 notation. CCIR-601 changed the luminance sample rate to 13.5 MHz for both NTSC and PAL but the 4:2:2 notation for Y U V sample ratio continued even though the relationship to subcarrier frequency was more complex.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
Since the TBC converts its output back to analog, its internal sampling structure is not that important. Many older professional TBCs sample at 4:1:1, which is more than adequate for consumer analog VCRs.Originally Posted by WyoVideo
Other factors are more determinant of TBC image quality, such as the quality of the analog filtering, the timebase correction capability, etc. -
Thanks for those responses. That helps me understand some of what's happening in the process a little better.
I had looked all through the forum for such information and never thought to look it up on wikipedia.
Ed
TBC question
By Petergar in forum DVB / IPTVReplies: 1Last Post: 21st Apr 2011, 07:45 -
TBC suggestions: TBC-1000, AVT-8710, ADVC-300, TV1-TBC, or TV1-TBC-GL
By m27315 in forum RestorationReplies: 16Last Post: 24th Mar 2010, 01:36 -
JVC HR-S9800U TBC question
By moondogger in forum Capturing and VCRReplies: 10Last Post: 4th Aug 2009, 21:14 -
Canopus ADVC300 TBC question
By Valnar in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 5th Jan 2009, 12:04 -
TBC's, TBC's, TBC's, upto my knees ........ puzzling over sync controls?
By StuR in forum RestorationReplies: 6Last Post: 22nd Nov 2007, 11:58
