Hello,
Is there a simple way to add opening credits when authoring a DVD?
Basically what I want to do is have 1 page of credits appear on the screen for a few seconds before the DVD goes to the main menu.
Is there a way to do this with TMPGenc DVD author or ULead DVD movie Factory? These are the programs that I use to author my dvd's.
Thanks,
gammer
tmpgenc dvd author
add the credit clip.
add the main movie as the other track. (click add new track when adding new mpg clips).
set the firstplay to play the first track.
search for firstplay for more information.
see
https://www.videohelp.com/forum/viewtopic.php?p=1428468#1428468 -
Perfect, thanks Baldrick.
Now, what is the best way to create the intro clip?
Can it be created from a jpeg and converted into a moving jpeg somehow?
Thanks again,
gammer -
Hi gammer....
I do my intros by creating a mpeg using either Mpeg Video Wizzard (by Womble) or Showbiz (by Arcsoft). Then import it into your fav autoring program (I use Dvd Lab .... love it!) and then set it as your first play movietitle. You can even get creative and add some cool transition effects: i.e. I created a stream consisting a simple text intro then added a fade-in effect that leads into a slideshow if you will featuring all of my additional dvd featurers. Get really creative and and some background music!
Kay -
I found how to make credits with Windows Movie Maker. You can do some pretty neat things.
It does, however, save the file in WMV format. But you can drop this into TMPGEnc and convert it to mpeg.
Best part of all is its free!
Thanks again for all the help,
gammer
Add credits to native camcorder video without recode ?
By bulgom in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 4th Jan 2012, 22:18 -
Editing Opening and Ending Credits in an MKV
By TheLaserdisc in forum EditingReplies: 3Last Post: 8th Jul 2011, 01:55 -
X264 closing down
By asiafan in forum Blu-ray RippingReplies: 16Last Post: 6th Jan 2011, 13:13 -
AutoGK closing by itself?
By loveberri87 in forum DVD RippingReplies: 0Last Post: 11th Aug 2008, 00:26 -
Closing Multisession tracks?
By When in forum Authoring (DVD)Replies: 9Last Post: 30th Jul 2008, 04:15
