Help, I use Nero Vision Express to make my DVD's from several movie files and it can convert almost anything to DVD format. But it is verrrryyy slow. Anyone know of alternatives? One that can convert multiple files into one DVD (video_ts) really fast even on older machines? thanks....
Most of the all-in-ones are a little slow. If you are just speaking about encoding, then Mainconcept and CCE are some of the faster ones.
You need to determine where your programs are operating slowly. If it's encoding, then the ones above will help. But creating a DVD from something like a Divx file takes some time. There are a lot of conversions happening, video format, sound, creation of menus, etc.
Try DivxToDVD. There's a freeware version available. If it does the same process faster, then you are one the right track. Or try some of the other all-in-ones listed it 'Tools' to the left. <<<<
The preferred way for best quality is to use individual tools for encoding and authoring, and often burning. Sometimes that can be even slower.
And how do you define 'slow'? It will likely take twice the playing time of most videos to do a 'fast' encode. Throw in a few more conversions and it will be even slower.
BTW, This is not DVD Authoring. Moving you.
What's the quickest/easiest way to cut something from DVD and DivX
By dsajkw in forum EditingReplies: 2Last Post: 2nd Sep 2010, 11:50 -
Quickest method of converting avi to DVD ???
By blinky88 in forum Video ConversionReplies: 15Last Post: 10th Oct 2009, 01:09 -
Quickest way from Camcorder to DVD
By Priapism in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 25Last Post: 26th Aug 2009, 13:07 -
What is the quickest way to get an mpeg onto a playable dvd?
By pugvader in forum Newbie / General discussionsReplies: 4Last Post: 1st May 2009, 14:57 -
Quickest Way to Rip My DVD's?
By Rjupiter in forum Newbie / General discussionsReplies: 16Last Post: 19th Mar 2008, 13:11
