I've got a Phillips 8631 DVD+-RW burner and I am trying to burn a duallayer dvd that is over 4.5 GB on some verbatim media. I made the dvd files with DVD-lab but when I go to burn them with nero it tells me the compilation wont fit on the DVD. However the DVD files are only about 7 gigs. What am I doing wrong? Thanks
Results 1 to 11 of 11
Is your version of Nero compatible with Dual Layer media ? Don't forget all this DL lark is quite recent - if you're using a vintage version of Nero that would explain a lot.
Hmm, I guess I should check the version. There is nothing you have to do different though for burning DL?
nope, same as dvd+r. Check to see if in the settings it gives you the option to from single to dual layer burning?
What We Do In Life, Echoes In Eternity.... -
I believe you have to have Nero 6 or beyond to burn dual-layer. A good way to check to see if Nero recognizes your media as dual-layer is after you have placed all your authored files into the Video Folder, check the bottom right of the the Nero window. It will tell you if it reads the disc as 8.5GB or 4.7GB.
Word of caution burning dual-layer with Nero, once you figure out whats wrong. There have been more than a handful of reports of Nero not properly burning at the layer break. This leads to discs stop playing or stuttering at that point. I too have had this dreaded mishap.
I would recommend a tool called CopyToDVD, which is offered by the creators of DVD-lab at a slightly discounted price. Check at Mediachance.com. Burns my dual-layer discs perfect every time. -
I would recommend it BIG TIME over Nero. I still use Nero 6.xxx to burn my regular single layer 4.7GB discs, but I no longer trust it to burn dual-layer discs. Its hit or miss with Nero. I have been told that Nero places the layer break (through its intricate calculations) in the wrong place. So when your DVD player gets to that point, it gets confused because it does not see whatever code should be there and this causes anything from a pause, a stutter or a complete stop. The dual layer discs are much too expensive to miss on your burns.Originally Posted by greymalkin
I have been using CopyToDVD for 2 months now, with about 10 burns and all 10 or so have been home-runs (for non-Americans, thats a GREAT thing
). No layer break probs.
this is good news..i have ordered a dual layer burner and as soon as I find a good price on some dual layer media (mine will do DVD+R DL and DVD-R DL..any preferences?) I'll finally get this thing to disc!
read copytodvd works fine for both SL & DLOriginally Posted by greymalkinWhat We Do In Life, Echoes In Eternity....
Rip DVD-R's, edit out commercials, burn new DVD Dual Layer...software?
By ruehl84 in forum Authoring (DVD)Replies: 5Last Post: 23rd Feb 2012, 04:06 -
Can my dvd drive burn to dual layer disk?
By HartsVideo in forum DVD & Blu-ray WritersReplies: 7Last Post: 3rd Oct 2010, 16:07 -
Dual Layer Burn Speed
By webstar in forum MacReplies: 8Last Post: 17th Sep 2009, 01:37 -
can I burn 2 AVI files to dual layer with toast
By BattyRoy in forum MacReplies: 6Last Post: 10th May 2008, 01:10 -
wont burn dual layer
By mark o in forum Newbie / General discussionsReplies: 7Last Post: 26th Jun 2007, 21:04
