All right... I read the how to's on this, but AVI-Mux GUI seems to corrupt the video. I have dual audio and dual subtitle .OGM and .MKV files that I would like to demux, convert to AVI, and mux the extra audio and subtitles in so that I may burn a bi-lingual DVD with optional subs.
Here's what I use for DVD Authoring: NeroVision Express SE
I have the following tools to use for the muxing and conversion process:
MEncoder
VirtualDub Mod
dBpowerAMP MC
AVI-Mux GUI
Like I said, everything runs smoothly. I can demux everything into separate files. The problem is that when I mux it with AVI-Mux GUI the file becomes a corrupted AVI. If someone has the time to give me step-by-step instructions (incase I am in fact doing something wrong), it would be much obliged (or if you would recommend a better method).
Thanks again.
I don't have a signature. This is just your rather intrusive imagination.
why mux to avi? convert to dvd with something else than nerovision cause it doesn't support any bilingual audio and optional subs like avi2dvd.
or do you just want avi?
and this is not just authoring so use the general forum. moving you. -
Well I tried using avi2dvd once, but I suppose I was too impatient and the menu editor really kind of turned me off to it. It's kind of difficult and the way it blinks when you click to move things is rather annoying.
I suppose I'm just being too picky. If there's a how-to on using that, please link it and I'll definitely check into it. Thanks.I don't have a signature. This is just your rather intrusive imagination.
Converting OGM and MKV
By Jeikobu in forum MacReplies: 9Last Post: 3rd Jun 2011, 01:30 -
.mkv/.ogm to .avi w/ subtitles
By Xandal in forum Video ConversionReplies: 15Last Post: 1st Sep 2008, 02:17 -
troubles with MKV/OGM to MP4
By ironmaidens in forum Video ConversionReplies: 6Last Post: 23rd Aug 2008, 14:18 -
MKV & OGM to RM under 100mb
By bloodyred in forum Video ConversionReplies: 2Last Post: 10th Sep 2007, 18:06 -
Ogm and mkv with subs in forntrow
By Senmet in forum MacReplies: 1Last Post: 13th Jul 2007, 09:46
