Are there any Dos base programs or commands to erase dvd-rw?
I have a Staples dvd-rw which I would like to try and erase. I can not do this thru WinXp because it locks up Window Explorer and any other program that tries and access the dvd-rw.
I was using the dvd-rw to test a ripped movie, the burning program reported a burn error. It did not say what the problem was. However after that the dvd-rw has become unusable.
So I was looking to see if I could do this from dos.
SeeYa
Never Say Never (Romeo Void 1981)
Firefox, Thunderbird -
Try running ImgBurn/DVDDecrypter from the command line with the /ERASE switch
/Mats -
How about CDRecord ProDVD?
It can be used easily with burnatonce, and if you look in the right place (burnatonce FAQ page) you'll find a Free key to use ProDVD.
ImgBurn/DVDDecrypter would still be the easiest.
Yep, I was thinking DVDDecrypter in CL mode also.
If in doubt, Google it.
Editing the commands of the buttons on the DVD menu?
By rone in forum Authoring (DVD)Replies: 24Last Post: 18th Jun 2011, 04:35 -
PgcEdit v7.4: a free DVD commands editor.
By r0lZ in forum Latest Video NewsReplies: 61Last Post: 22nd Mar 2010, 14:54 -
TMPGEnc DVD Author 3.0.5.149 - subtitles with italic commands
By lienny in forum Authoring (DVD)Replies: 9Last Post: 20th Jan 2009, 20:27 -
DVD VM Commands
By TonitoDJ in forum Authoring (DVD)Replies: 1Last Post: 24th Nov 2008, 09:55 -
Question about certain dos commands
By jimdagys in forum ComputerReplies: 35Last Post: 15th Oct 2008, 22:57
