I bought this at Walmart for $98. It seems to play everything ok. Records to dvd-r/rw. The big problem is that the tuner will not work. It gets no signal from antenna, gets one channel from cable and it's in black n white. I returned one and the 2nd has the same problem.
I guess you get what you pay for.
How likely is it that two of them have the same problem?
Not very. I'd check for something else."Art is making something out of nothing and selling it." - Frank Zappa
Ilo DVDR04
By 2003 Hayabusa in forum Newbie / General discussionsReplies: 4Last Post: 2nd Sep 2010, 14:48 -
Need files to update ILO DVDR05/ZU cant find anywhere
By strbyz1 in forum DVD & Blu-ray RecordersReplies: 0Last Post: 22nd Aug 2009, 21:48 -
Ilo DVDR04 replacement drive
By emyly7 in forum DVD & Blu-ray RecordersReplies: 11Last Post: 21st Aug 2009, 03:12 -
ILo dvd recorder not cooperating
By jhayes in forum DVD & Blu-ray RecordersReplies: 9Last Post: 9th Dec 2007, 10:06 -
Feeding ilo DVDR05 output directly to PC, is it possible?
By superspeedfreek in forum DVD & Blu-ray RecordersReplies: 3Last Post: 4th Jun 2007, 12:43
