  1. I am trying to recode an unprotected DVD with nero recode 2 but get an error message just a few minutes after I start. Enclosed is the log. I don't have a DVD burner installed but I thought the recoding process would complete.
    Project type: Copy entire DVD
    Target size: DVD5 (2282925)
    10:23:20 File LangStreamPatcher.cpp, Line 56
    Command table patching started...
    10:23:20 File LangStreamPatcher.cpp, Line 103
    VTS 1 - VTSM_PGCI_UT - LU 1 - PGC 3 patched!
    VTS 1 - VTSM_PGCI_UT - LU 1 - PGC 13 patched!
    VTS 1 - VTSM_PGCI_UT - LU 1 - PGC 14 patched!
    10:23:20 File LangStreamPatcher.cpp, Line 135
    All tables successfully patched!
    Burn settings:
    Target: Hard disk folder
    Number of copies: 1
    Target folder: D:\raysoft (12956614656 bytes free)
    Shutdown when finished: false
    Advanced Analysis: true
    Compress Adaptive: true
    10:23:37 File burn_dvdfiles.cpp, Line 231
    Compile DVD: init
    VMG Menus Vobs [1 vobus] 0.11MB -> 0.02MB [R 0.02]
    Video: 0.02MB, extra: 0.00MB
    Audio: 0 streams
    Subpicture: 1 streams
    0. 0. Unspecified 0.00MB [enabled]
    VTS_01 Menus Vobs [175 vobus] 37.31MB -> 24.05MB [R 0.02]
    Video: 21.57MB, extra: 2.48MB
    Audio: 1 streams
    0. 0. Dolby Digital 2-ch Unspecified 1.98MB [enabled]
    0. 0. Unspecified 0.16MB [enabled]
    VTS_01 Title Vobs [15819 vobus] 4434.56MB -> 4434.56MB [R 1.00]
    Video: 3563.33MB, extra: 871.23MB
    Audio: 8 streams
    0. 0. Dolby Digital 5.1-ch English 370.95MB [enabled]
    1. 1. Dolby Digital 5.1-ch Chinese 432.63MB [enabled]
    2. 2. Dolby Digital 5.1-ch English 0.00MB [enabled]
    3. 3. Dolby Digital 5.1-ch English 0.00MB [enabled]
    4. 4. Dolby Digital 5.1-ch English 0.00MB [enabled]
    5. 5. Dolby Digital 5.1-ch English 0.00MB [enabled]
    6. 6. Dolby Digital 5.1-ch English 0.00MB [enabled]
    7. 7. Dolby Digital 5.1-ch English 0.00MB [enabled]
    Subpicture: 32 streams
    0. 0. English 7.25MB [enabled]
    1. 1. Thai 6.65MB [enabled]
    2. 2. Chinese 7.01MB [enabled]
    3. 3. Unspecified 7.74MB [enabled]
    4. 4. Korean 8.11MB [enabled]
    5. 5. Unspecified 0.00MB [enabled]
    6. 6. Unspecified 0.00MB [enabled]
    7. 7. Unspecified 0.00MB [enabled]
    8. 8. Unspecified 0.00MB [enabled]
    9. 9. Unspecified 0.00MB [enabled]
    10. 10. Unspecified 0.00MB [enabled]
    11. 11. Unspecified 0.00MB [enabled]
    12. 12. Unspecified 0.00MB [enabled]
    13. 13. Unspecified 0.00MB [enabled]
    14. 14. Unspecified 0.00MB [enabled]
    15. 15. Unspecified 0.00MB [enabled]
    16. 16. Unspecified 0.00MB [enabled]
    17. 17. Unspecified 0.00MB [enabled]
    18. 18. Unspecified 0.00MB [enabled]
    19. 19. Unspecified 0.00MB [enabled]
    20. 20. Unspecified 0.00MB [enabled]
    21. 21. Unspecified 0.00MB [enabled]
    22. 22. Unspecified 0.00MB [enabled]
    23. 23. Unspecified 0.00MB [enabled]
    24. 24. Unspecified 0.00MB [enabled]
    25. 25. Unspecified 0.00MB [enabled]
    26. 26. Unspecified 0.00MB [enabled]
    27. 27. Unspecified 0.00MB [enabled]
    28. 28. Unspecified 0.00MB [enabled]
    29. 29. Unspecified 0.00MB [enabled]
    30. 30. Unspecified 0.00MB [enabled]
    31. 31. Unspecified 0.00MB [enabled]
    10:24:17 File burn_dvdfiles.cpp, Line 1152
    Compile DVD: begin copy 1
    10:24:17 File NeroRecorder.cpp, Line 122
    Writing to harddrive folder started
    10:24:17 File burn_dvdfiles.cpp, Line 684
    Compile DVD: begin deep analysis
    10:24:30 File burn_dvdfiles.cpp, Line 381
    Failed to open the file 8圷.
    10:24:30 File burn_dvdfiles.cpp, Line 382
    Compiling DVD volume failed
    10:24:30 File burn_dvdfiles.cpp, Line 301
    Compile DVD: exit
    10:24:30 File burner.cpp, Line 993
    Failed to open the file 惐??
    USA
    I may be reading it wrong, but this line: Failed to open the file 圷. looks interesting. If that is really the filename I can see a problem with non-standard characters. Or the real name of the file is corrupted.
  3. Well I am in China and using Chinese Windows xp. Maybe that is causing a problem.
