I just purchase Philips DVP 642/37 Player.
I am using Memorex DVD+RW with Max Speed 2.4X.
I tried using Nero 7.x, burn to DVD No Session. I check and files was on DVD+RW through my computer. When I insert it into the DVP 642 Players. It keep reading forever and forever.
Is there any special way to burn on the the DVD+RW Disc?
Any unique way?
Results 1 to 9 of 9
Xvid and Divx Files in AVI format.Originally Posted by canadateck
I just burned DVD+R disc. It works fine.
I tried the DVD+RW and the player keeps reading it continuesly non-stop.
As for the Disc type.
Memorex 4.7 GB 2.4X DVD+RW
Also, my Burner is LIte-On 832S DVD -
I not sure how Nero works, I dont use it,But when using a DVD-/+RW you dont need to set (No Session).
I have the dvp-642, use the same Memorex DVD+RW and burn mine with Nero Burning Rom 6.xxx as data discs DVD-ROM udf/iso.
Don't use multi session.
I usually bitset mine to DVD-ROM but, before posting, I just checked a few that I did a long time ago set to DVD+RW and they work fine in the dvp-642 without bitsetting. -
Here is the disc info.
Drive Type = DVD DUAL
Disc Type = DVD+RW (Single Layer)
Disc MID = 49 4E 46 4F 44 49 53 43 (INFODISC)
Disc TID = 41 30 31 (A01)
Nominal Capacity = 4.38GB
Manufacturer Maybe = Infodisc Technology Co., Ltd.
SMART-BURN Speed Limit = 2.4X (Write) -
The DVP-642, like most DVD players, does have preferences for certain media above others. Personally, I think Memorex discs are absolute crap. No offense guys, but Memorex does not make high quality media. I would recommend to vodreaux to try good quality discs, such as Verbatim (my first choice) or Fuji. You should not burn in multi-session mode and you should use Disk At Once. I have successfully burned DivX files to Verbatim DVD+RW discs and had them play with no problem on this player.
That's funny my Memorex +RW 2.4 are media id RICOHJPNW01Manufacturer Maybe = Infodisc Technology Co., Ltd.
I bought mine a long time ago in 3 per box. I also have some 4x rated discs bought at 5 per box, id code PHILIPS 041.
Maybe they changed the discs since then. -
My new 642/37 is not playing TDK DVD+RWs. I'm having the same problem as vodreaux, with the "loading" message and whirring noise.
I thought TDK was a good brand, which is why I bought it (It had 5 stars on amazon.com). I'm using Nero express, although I usually use Burning Rom on my other computer. Could it possible be a program issue? I called up Philips and they told me it was either a region problem or the disc burning didn not finalize in a way the player could recognize the disk.
Philips DVP-642 16:9 Display
By wulf109 in forum DVD & Blu-ray WritersReplies: 4Last Post: 27th Jan 2010, 13:39 -
Philips dvp 642 help?
By imemine in forum DVD & Blu-ray PlayersReplies: 7Last Post: 3rd Feb 2009, 03:22 -
Philips DVP 5140 or DVP 642/37, which is better?
By Amuse in forum DVD & Blu-ray PlayersReplies: 2Last Post: 2nd Feb 2008, 17:26 -
Philips DVP 642 (37A) dvd player -does it play PAL
By Katiemay in forum DVD & Blu-ray PlayersReplies: 8Last Post: 12th Jun 2007, 00:16 -
Philips DVP-642 and x.264 HD encoding
By dfishman923 in forum Newbie / General discussionsReplies: 2Last Post: 13th May 2007, 15:36
