With all the channels available on the UHF band they couldn't find room for up to 12 tv stations? I will always believe the only reason they want to go digital is so they can have more control over what we can or can not do with the programming we receive.Originally Posted by edDV
Results 61 to 72 of 72
In reality, I think the date needs to be pushed out to give time for the cost to come down to reasonable consumer levels (with gratitude to the early adopters who pay for the R & D). That way the cost of 100% inclusion would be minimal, certainly less than the $20 from your set top box since most of the components are redundant (case, power supply, I/O connectors, even the pcb and retail packaging costs get cut out).
The need for the bandwidth is not so dire that the transition can't wait another 5 - 10 years, its being done for better utilization and grouping - similar to the reason Nextel/Sprint will be giving up its 800MHz iDEN band for public safety groups like police and fire.
Imagine the uproar if/when they try to consolidate out the FM radio band.
The thought process behind forcing inclusion in large (> 27") TVs is sensible from a cost perspective, but totally backwards from a real world end use standpoint. The reality of it is that its the small TV that will need the internal tuner because its going to end up in the bedroom, basement or garage.
The $20 - $50 price for a set top converter is (at best) an educated guess on your part. Nobody can predict the actual costs until the silicon is done and you are running production volumes. And with typical setbacks associated with such a complicated ASIC its likely that it won't even be ready (in its final form) in time for the proposed cut off.
As far as encryption is concerned, there is no doubt its actual purpose is to incorporate DRM (of some form or other) into every broadcast signal. Digital encryption simplifies the process greatly, but as long as there is an analog output somewhere the system will never be 100% secure. -
Originally Posted by hudsonf
This site covers most of the issues from the viewpoint of an antenna seller but is a bit weak on ATSC DTV. Where they say HDTV, substitute DTV. HDTV is only an augmentation to digital broadcasting. I'll add more links.
http://www.tvantenna.com/support/tutorials/uhf.html
another perspective (scroll down to "Why Digital Television?")
http://www.bsss.org/digital_tv.htmRecommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
edit
The FCC's original drop-dead date for the cessation of all regular analog television broadcasting in the US was to be May 1, 2006 (less than five years away). Since that ruling, a loophole was added saying that analog television can't be shut down until 85% of viewers in a market can receive digital signals. How long will that take? If history is a guide, from the time color television was introduced in 1953, it took until 1978 for 50% of viewers to have color TV sets in their homes. That was 25 years. So you won't need to buy a DTV set today.
And even more to my original point:
But to those of us who work in the broadcasting industry, it is a frustrating time of transition -- -a government-mandated transition that most TV viewers are unaware of!
Granted it won't affect a geat deal of those people, but I'd be willing to bet that the people who it will affect the most are precisely the people who are most in the dark about it. -
I think we passed 85% long ago. This year even the smallest markets have parallel DTV service. Many are operating at low power until the analog shutoff. All it takes is a gov't mandated power boost and the number will be surpassed. If you are using that as your arguement then analog could be shut off in 2006.
http://www.nab.org/Newsroom/issues/digitaltv/DTVStations.asp
North Platte, Nebraska (the 209th market, pop 23,944) has 3 DTV stations.
I don't see your other point. Many don't know it's against the law to have your windshield wipers on and not your headlights. Hundreds are being ticketed every day. Should those cases be thrown out of court because the violator was ignorant of the new law?
The broadcasters are still going through lotteries to determine their final channel numbers after analog shutoff.
http://www.avsforum.com/avs-vb/showthread.php?t=591927Recommends: Kiva.org - Loans that change lives.
Just because the signal is being broadcast does not mean that 85% of the market can receive it. But I have to question how they will determine when 85% will have the capability to receive the digital transmission.
Buy My Books -
Originally Posted by gadgetguy
To find your local analog and digital TV stations plug your address into http://www.antennaweb.org/
Digital station power will be raised before the shutoff so everyone can have their ducks in line and antennas pointed.
Note that some markets will continue to have digital stations in the upper VHF (ch 7-13) in the first phase. FM Radio sits just above Ch 6. That frees all TV frequencies below 85 MHz. Analog TV (ch 2-6) currently occupies 35% of the bandwidth below 85 MHz.Recommends: Kiva.org - Loans that change lives.
Of course, the actual text of the loophole may be different and may mean that the signal must be available to 85% of the market before disconnecting. Does anyone have a link to that actual text?"Shut up Wesley!" -- Captain Jean-Luc Picard
Buy My Books -
This chart shows current frequency allocations in the USA for the radio spectrum. Note how much space is being taken currently by broadcasters (blue). It is a logarithmic base so the blue in the upper frequencies represents even more that it looks. Other nations have similar allocations.
Ch-2-6 will be made available for lease in all markets plus portions of the upper VHF Ch 7-13. Meanwhile the UHF TV band has/is being reduced in half from 70 to less than 35 channels total. Digital technology makes this possible.
http://www.ntia.doc.gov/osmhome/allochrt.pdfRecommends: Kiva.org - Loans that change lives.
What year was Video8 introduced to the world
By beammeup in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 10th Mar 2012, 10:29 -
how to convert a hole folder?
By alina-pia89 in forum ffmpegX general discussionReplies: 2Last Post: 9th Jan 2010, 23:11 -
Where's that freakin black hole!?
By maxamillion in forum Off topicReplies: 13Last Post: 11th Oct 2008, 16:20 -
New Canadian anti-P2P legislation (Here come the bogus lawsuits)
By Hank Kinsley in forum Newbie / General discussionsReplies: 2Last Post: 13th Jun 2008, 09:16 -
how do i see hole movie with out stoping for new file..
By DenverJeepMan in forum Authoring (DVD)Replies: 6Last Post: 6th Dec 2007, 17:51
