I have attached the partial log file below. Basically, I'm trying to take some .AVI's I have and burn them onto a DVD via NERO Vision so I can watch them on my DVD player. About halfway through the process it just ejects the DVD and gives me an error log file. Can someone decipher these for me?
nerologfile2.txt
Nero is a bad encoder.
Nero is bad with DL media.
The end. Sorry.
Encode in advance. Use a better burning software.
A forum search would have revealed all those. Find some post by Edmund Blackadder.Want my help? Ask here! (not via PM!)
Ok, but before I abandon Nero so quickly I'd like to know if anyone can decipher this error log, maybe its something I'm doing wrong or a hardware incompatability issue?
Not that I can read the log, but it apparently failed at the layer break. Looking around the net, that seems a common failure point with burning DL discs.
You would have to study more about layer break burning problems to come up with a solution. Check the forums on http://club.cdfreaks.com for better info. -
Only thing is that I have to encode the .avi's into MPEG and then burn. I tried another DL disk after I downloaded new firmware for my burner and still the same thing. Its pissing me off how many DL coasters I'm getting!
[17:16:01] DVDEngine 5:16:01 PM #62 CDR -1206 File BurnAtOnceRecorder.cpp, Line 1939
[17:16:01] DVDEngine Burning Layer 2
[17:16:01] DVDEngine 5:16:01 PM #63 SPTI -1064 File SCSIPassThrough.cpp, Line 306
[17:16:01] DVDEngine CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1064)
[17:16:01] DVDEngine Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
[17:16:01] DVDEngine Sense Code: 0x21
[17:16:01] DVDEngine Sense Qual: 0x02
[17:16:01] DVDEngine CDB Data: 0x2A 00 00 00 00 01 00 00 20 00 00 00
[17:16:01] DVDEngine Sense Area: 0x70 00 05 00 00 00 00 0A 00 00 00 00 21 02
[17:16:01] DVDEngine Buffer x09997c00: Len x10000
[17:16:01] DVDEngine 0xB5 14 82 00 01 00 00 00 00 01 B8 00 DF 4E 00 00
[17:16:01] DVDEngine 0x00 01 00 00 8F FF F8 00 00 01 B5 8F FF F7 0C 00
[17:16:01] DVDEngine 0x00 00 01 01 12 87 F1 29 40 D3 59 B4 DC A9 E9 1A
[17:16:01] DVDEngine 5:16:01 PM #64 Text 0 File BurnAtOnceRecorder.cpp, Line 1954
[17:16:01] DVDEngine Failed to write 96 sectors after layer break
https://forum.videohelp.com/viewtopic.php?t=280113&highlight=dual+layer+burning+nero
Your software version is:
[17:16:01] DVDEngine ahead WinASPI: File 'C:\Program Files\Nero\Nero 7\Core\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 11/2/2004 1:54:32 PM
Good luck!
TTWC"I've got a present for ya!" - TTWC
NERO Vision Won't Produce DVD's
By Ensign in forum DVD RippingReplies: 11Last Post: 29th Sep 2009, 10:43 -
HELP Burn using Nero Express doent work /but NERO VISION work fine
By STAR36 in forum Authoring (DVD)Replies: 4Last Post: 28th Apr 2008, 16:11 -
DVD Shrink/Nero burn errors
By chibimaru in forum DVD & Blu-ray WritersReplies: 7Last Post: 1st Jun 2007, 03:22 -
DVD in INTERLACE and nero Vision 3
By Psycogeek in forum Authoring (DVD)Replies: 10Last Post: 22nd May 2007, 22:34 -
join and burn using winavi and nero vision express?
By leogeo in forum Authoring (DVD)Replies: 9Last Post: 11th May 2007, 06:56
