Results 1 to 10 of 10
goldwave, sound forge , cool edit , vegas, etc .... all can do it also .....
if you mean wav files that is ...
if you mean ac3 files ... you can do it directly in vegas (now)"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
I used IFO EDIT and change all the IFO's in the Video_ts folder to referrence NTSC in both menu and film info. You must change ALL lines that have PAL to NTSC or it will not work. I have done this to several films to test on about a 8 different DVD player barnds with 100% success. I am aware some do not believe this to be a good conversion, and not consistant, but it beats a 22hour re-encode with Vegas 6. There is sometimes a slight green to it. Good luck.
he asked about audio
it is the same as stretch , keep pitch
you just have to determine how much - which is easy"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
I get both the audio AND video in one shot with ifo edit. I do not have to do anything else if the audio is in DD 5.1 or PCM. I do, however, use Decryptor to demux both audio and video streams and import in Vegas for re-encoding for sources with sync issues and undesireable/workable formats. Never had a problem with it.
Pls help! Best way to convert NTSC VHS (captured using PAL VCR) to NTSC DVD
By rairjordan in forum Capturing and VCRReplies: 33Last Post: 28th Nov 2013, 12:33 -
Convert PAL to NTSC?
By killerteengohan in forum Video ConversionReplies: 32Last Post: 7th Feb 2012, 12:33 -
How to Convert NTSC to PAL
By Gusto747 in forum Video ConversionReplies: 14Last Post: 19th Aug 2010, 20:52 -
By rock.freak667 in forum DVD RippingReplies: 8Last Post: 21st Jul 2009, 09:16 -
How to convert PAL DV to NTSC (I ONLY have NTSC DV camcorder to play with)
By inspiron2 in forum Video ConversionReplies: 4Last Post: 7th Jul 2008, 22:45
