Anyone here know how and what program to use to rip Karaoke discs so they can be used in the Karaoke player?
Thanks![]()
J
Results 1 to 11 of 11
CD+G or DVD? CD+G require a specific CD Rom that reads CD+G. DVD is ripped as usual.
What is needed for a CD+G? I have 10 disc and all i get is the audio portion, never the graphic part. Any help would be appreciated. -garmanOriginally Posted by smearbrick1
Probably need to rip it as an image in Nero or something (disc juggler, Alc 120% etc)
What have you tried so far?
Copy it as a data disc, but you have to make sure that the file layout and structure are changed, like alphabetizing files that shouldn't be in that order.snappy phrase
I don't know what you're talking about. -
I am lost with macs.
Try the discjuggler demo, but I am not sure, if it will work.
What is on the disc when you explore it?snappy phrase
Are these CD+G karaoke discs or DVD karaoke discs?Originally Posted by garman
If they are CD+G, you will need a CD-ROM drive that reads CD+G discs. Otherwise, all you'll get is audio. -
What DVD/CD burner support cd+g?Originally Posted by smearbrick1
this might helpOriginally Posted by garman
http://www.tricerasoft.com/drivelist.html -
Thanks! , I wonder if you need the same burner to make cd+g or is it you can just rip with the below mentioned drives and burn with a non compatible drive- garmanOriginally Posted by ps2daddy
Dunno but if you had one of those drive it would definitely work
Ripping dual audio tracks Karaoke DVD
By Longhorn1955 in forum Newbie / General discussionsReplies: 3Last Post: 7th Dec 2011, 23:14 -
I need help with Karaoke DVD to Karaoke VCD(MPG)
By adrianneow in forum Newbie / General discussionsReplies: 1Last Post: 8th Jun 2011, 09:02 -
best optical disc drive for ripping audio CDs with scratches ???
By flashandpan007 in forum AudioReplies: 1Last Post: 5th Jun 2011, 14:25 -
Ripping Karaoke DVD to VCD (.DAT) (Mpeg1)
By Nhuii in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 20th Aug 2010, 23:01 -
How to rip and burn (What to use for both) Karaoke Cds???? Please help. tha
By slayer_of_all in forum Newbie / General discussionsReplies: 6Last Post: 7th Jan 2010, 19:30
