I cant play avi file right (no picture) because i dont have right decompressor and it says it's IV50 PCM. what is that? codec? where can I get it?
Results 1 to 10 of 10
IV50 stands for Indeo Video version 5.0. Indeo was a subdivision of Intel and was bought by Ligos a few years back and vanished into thin air. Normally this codec is installed as a standard Windows item, but here is a link to a download version of IV 5.11. (This is so new it is only supported by processors with MMX technology!! :P )
http://www.free-codecs.com/download/Indeo_Codec.htm -
Indeo 5.x is not included as part of windows .. and the latest versions they make you pay for - but i dont see many people using it ...
All my Windows XP installs included Indeo Video 5.10.Originally Posted by BJ_M
The following table lists the codecs included with Windows XP (NO service pack):
Manufacturer Model
DSP Group TrueSpeech Software Audio Codec
Intel Indeo R3.1 Video Codec
Indeo R3.2 Video Codec
Microsoft Audio codecs ADPCM Audio Codec
CCITT G.711 A-Law and u-Law Audio Codec
GSM 6.10 Audio Codec
IMA ADPCM Audio Codec
Microsoft Video codecs RLE Video Codec
Video 1 Video Codec
SuperMatch Cinepak Video Codec"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
http://support.microsoft.com/default.aspx?scid=kb;en-us;899113
Audio codecs in Windows XP SP2
Codec Company
IMA ADPCM Microsoft
Microsoft ADPCM Microsoft
Microsoft CCITT G.711 (A-Law and u-Law) Microsoft
Microsoft GSM 6.10 Microsoft
DSP Group True Speech DSP Group, Inc.
Windows Media Audio Microsoft
Sipro Lab Telecom Sipro Lab
Intel Audio Software (Indeo 2.5) Intel
Franhofer IIS MPEG Layer-3 (Advanced) Fraunhofer-Gesellschaft IIS
Microsoft PCM Microsoft
Windows Media Audio 9 Voice Microsoft
Windows Media Audio 9 Microsoft
Windows Media Audio 9 Professional Microsoft
Windows Media Audio 9 Lossless Microsoft
Back to the top Back to the top
Video codecs in Windows XP SP2
Codec Company
Cinepak Radius (Supermac/Compression Technologies Inc.)
DV Microsoft
Indeo Video 3.2 Intel
Indeo Video 4.5 Intel
Indeo Video 5.10 Intel
Indeo iYUV R2 Intel
RAW YVU9 Video Driver Intel
MJPEG Microsoft
MPEG-1 Video Decoder Microsoft
Microsoft ISO MPEG-4 V1 Decoder Microsoft
Microsoft ISO MPEG-4 V1.1 Decoder Microsoft
Microsoft CRAM Microsoft
Microsoft MPEG-4 (V1) Microsoft
Microsoft MPEG-4 (V2) Microsoft
Microsoft MPEG-4 (V3) Microsoft
Microsoft RLE Microsoft
Windows Media Screen (V7) Microsoft
Windows Media Screen (V9) Microsoft
Windows Media Video Standard (V7) Microsoft
Windows Media Video Standard (V8) Microsoft
Windows Media Video Standard (V9) Microsoft
Windows Media Video V9 Image Microsoft
Codecs in Windows Media Player 9 Series
Codec Company
Windows Media Video 9 Microsoft
Windows Media Video 9 Screen Microsoft
Windows Media Video 9 Image Microsoft
Note Windows Media 9 Series codecs are integrated with Windows XP SP2.
Codecs in Windows Media Player 10
Codec Company Description
Windows Media Audio Microsoft This codec is used to encode complex audio files, such as music files. The most recent versions of this codec are the Windows Media Audio 9 codec and the Windows Media Audio 9.1 codec.
Windows Media Audio Professional Microsoft This codec is used to encode complex audio files, such as music files. This codec supports multichannel encoding and 24-bit encoding. Two versions of this codec are the Windows Media Audio 9 Professional codec and the Windows Media Audio 9.1 Professional codec.
Windows Media Audio 9 Lossless Microsoft This codec is used for lossless encoding of audio files. Two versions of this codec are the Windows Media Audio 9 Lossless codec, and the Windows Media Audio 9.1 Lossless codec.
Windows Media Audio 9 Voice Microsoft This codec is optimized for encoding the human voice at a high compression ratio. This codec is the preferred codec for encoding data streams that primarily consist of spoken words. For content that is a mixture of music and speech, this codec yields a very high quality audio file.
Windows Media Video 9 Microsoft This codec is used to encode complex video files, such as movie files. The Windows Media Video 9 Advanced Profile Video codec is a version of this codec. The Windows Media Video 9 Advanced Profile Video codec is incorporated into advanced encoding features such as interlaced encoding.
Windows Media Video 9 Screen Microsoft This codec is optimized for encoding sequential screen shots. For example, this codec is frequently used to record screen shots of monitor images of software applications. The monitor images are later used for software training.
Windows Media Video 9 Image Microsoft This codec is used to convert bitmap images with the deformation information into a compressed video. Two versions of this codec are the Windows Media Video 9 Image codec, and the Windows Media Video 9 Image v2 codec.
Notes
• Windows Media Player 10 is available as a feature of Microsoft Windows XP.
• Codecs that are updated by Microsoft Windows Media Format 9.5 Runtime are included in Windows Media Player 10 and in the third-party products that use the Windows Media Runtime format.
• Audio codecs that are updated by Microsoft Windows Media Format 9.5 SDK are included in Microsoft Windows Media Format 9.1.
• Video codecs in Microsoft Windows Media Format 9.5 SDK do not update codec version numbers.
• Codecs in the Windows Media codec table may be used in an Advanced Systems Format (ASF) container that is protected by Windows Media Digital Rights Management (WMDRM).
• The most recent version of Microsoft Windows Media Player 9 Series SDK runtime and the re-released version of Windows Media Player 9 Series have been updated with Windows Media 9.1 codecs."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
he may have need for the Indeo XP package and/or 5.2 , both of which are not free
yes correct , but many dont want to install sp2 , or have not done so
nor does it include 5.2 / XP package"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
Thank you so much for the link. I have Vista and had an old training video at work that would not play because it was in an avi format...You saved my butt for my meeting tomorrow.
AVI won't play. VLC say's doesn't support "IV50" Format. All codecs present
By Sikander in forum Software PlayingReplies: 2Last Post: 21st Feb 2010, 08:40 -
Vista and Windows 7 both have problem with Indeo IV50
By paj692 in forum Software PlayingReplies: 1Last Post: 8th Jan 2010, 20:30 -
PCM vs AC3
By Reading Bug in forum AudioReplies: 14Last Post: 1st May 2009, 05:34 -
Help/info on IV50 "Indeo Video 5" codec....
By petruccibanez in forum MacReplies: 3Last Post: 4th Apr 2008, 01:22 -
PCM to Wav
By woodie in forum AudioReplies: 2Last Post: 4th Jun 2007, 11:53
