    Dec 2005
    Austria
    Heyho,
    Well this is my first post here. I normally don't post reply's but i can't find help anywhere (I used boardsearch, google, etc...)
    I like to rip the DVD with DVDDecrypter and use DVD2SVCD (in DVD to DVD Mode) with CCE as Encoder.
    Is there a method to keep the menu and subs untouched and only reencode the Main Movie and keep only 2 languages (.de and .en AC3 2.0)?
    Usefull notes:
    I want to burn my Scrubs S01 Box but I don't like this One-Click Tools like DVD Shrink
    Edit:
    I've done a 4,37GB DVDR, the video is reencodet and the audio, I wanted, is here but the menu is missing, can I add it to the encodet video or something?
    Thanx for help, and I hope my english isn't that bad
  2. Hi-
    I'd suggest using the free version of DVD Rebuilder. It supports CCE and you'll keep the menu untouched.
    I'm pretty sure you can, but if you're already at 4.37 GB, unless that menu is pretty small, you may not have room. Try this guide:
    https://www.videohelp.com/~jsoto/guides/VobBlanker/adding_menus/index.htm
    Dec 2005
    Austria
    Okay thanx.
    I'm gonna read it and then try, if I don't edit this post it means I've done it correctly
