lately i couldnt burn any dvd using my hp burner that came with the system ... does that mean that i have to buy a new one to replace it
thanks
Sorry my mind reading skills aren't what they used to be. Perhaps more info will help us to provide the answer you seek.
sorry if i dont give much info .. what should i do to check if i need to buy a new dvd burner. thanks
-edit-
Does the light come on? Will it read a cd or dvd? What messages do you get when you try and burn a dvd? Have you tried a different dvd media brand? Does your computer recognise the dvd player? Is ATA/UDMA on or off? Is DMA enabled? Have you tried new ASPI drivers? etc.
Incorrect Timing on DVD burn: H.264 mp4->ffmpegx->Toast or Burn
By DirectorSG in forum MacReplies: 2Last Post: 29th Jan 2012, 12:42 -
Why are cdr burn rings lighter than dvdr burn rings?
By yoda313 in forum Newbie / General discussionsReplies: 4Last Post: 27th May 2010, 17:55 -
DVDs burn fine, but Audio CDs only burn 1st half of songs right...
By Xenogear900 in forum Authoring (VCD/SVCD)Replies: 7Last Post: 28th Jan 2010, 04:26 -
Advice required when trying to burn with img burn
By IPBR21054 in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 1st Aug 2009, 16:29 -
Burn Software with Menu & burn xvid avi
By CynthiaBlue in forum Newbie / General discussionsReplies: 3Last Post: 4th Jul 2007, 20:46
