i recently replaced a basic keyboard with a semi-fancy compaq keyboard.. the problem now is that it is using some advanced functions and its kind of bothersome.. for example, i cant alt+F4 to close pages anymore.. and the F# keys have weird assignments for them.. i didnt install any software for the keyboard..
does anyone know how i can make this keyboard act like a normal keyboard? maybe switching drivers or something?
What does it say in the keyboard properties in the control panel?
Believing yourself to be secure only takes one cracker to dispel your belief. -
Got a picture of this keyboard? Is there anything strange about it?
Some keyboards come with enhanced features that can be used (sometimes known as enhanced F keys). Under the enhanced mode, Standard F key operation is not permitted. Hence, you need to turn off or switch to standard F key mode. You may need to refer to the manual that came with the keyboard to change the operation mode.
On my keyboard, I have a button labelled F-Lock that allows me to switch between operations, maybe your keyboard has one too. -
okay. i installed the drivers for it and was able to use the F-on/off key to enable the keyboard to act normally.
thanks -
Originally Posted by lumis
Subtitle Workshop Acting Weird
By Startropic1 in forum SubtitleReplies: 4Last Post: 14th Jul 2010, 21:51 -
Mp4cam2avi is acting up!
By 24fps in forum Video ConversionReplies: 3Last Post: 21st May 2010, 22:54 -
WinDV acting goofy
By stantheman1976 in forum Capturing and VCRReplies: 5Last Post: 8th Feb 2009, 19:46 -
iMovie acting up
By Nilfennasion in forum MacReplies: 4Last Post: 13th Nov 2008, 09:28 -
FCP acting strange
By James in HD in forum MacReplies: 1Last Post: 12th Oct 2008, 00:06
