Hey, im looking for two tools. One is an over all good tool for joining two movies together. I'm hoping to find one that will allow me to not just join diff. formats together, but also let me see if the audio format is the same and the sound quility. Other then that im also looking for another tool really "user friendly" but professional to create menu's..ext. Thanks for the help in advance.
Nope. To join movies they need to be of the same format, bitrate etc. i.e. you will need to re-encode them unless they are of the same type.Originally Posted by nempo
Menu's for a DVD? Try TMPGEncDVDAuthor.Originally Posted by nempoRegards,
Rob -
Is there a good program that will help me convert a lot of diff types of formats?
TMPGenc/TMPGenc Plus for encoding ("converting") each file to required format. Will also join mpeg files ( don't recommend you join before encoding due to possible sync issues). For other formats (e.g .avi; IMO VDub is ideal) then look in 'Tools' section
TDA for authoring and menu creation-very "user friendly". Can join files at authoring stage.
Joining MP3's
By dfisher052 in forum AudioReplies: 24Last Post: 28th Mar 2013, 06:57 -
Joining
By breeze9 in forum EditingReplies: 2Last Post: 30th Dec 2007, 15:14 -
mpg joining?
By jay_lubb in forum Newbie / General discussionsReplies: 2Last Post: 23rd Aug 2007, 11:02 -
Joining mpeg4?
By chronic777 in forum EditingReplies: 5Last Post: 16th Aug 2007, 15:23 -
joining avi's
By php111 in forum EditingReplies: 15Last Post: 5th Aug 2007, 10:05
