Results 1 to 17 of 17
  1. I was at the local office max today and I saw a 100 pack dvd+r for 14.99 and I was wondering if they are good and on what types of hardware are they good on?
    I had a dream about insomnia the other night...
    When I woke up.. I thought.. I can finally get some sleep
  2. Member Faustus's Avatar
    Apr 2002
    Dallas, TX
    I dunno any specific about them but I'd beware ANY store brand media.
  3. I was wondering about the media code on those too.
  4. Well Ive been thinking it over.. (thinking hurts me ) and I think Ill buy a pack anyway. They are only 15 bux and thats not alot to lose (since xmas money is comin my way! hehe)
    Ill use dvd identifier and give a report on how well it burns for me. Seems no one knows!
  5. Member solarfox's Avatar
    Aug 2002
    Frankly, I will be astonished if they're anything other than bottom-of-the-craptacular-barrel CMC Magnetics discs... Don't waste your money; it only encourages them to keep foisting this stuff on unsuspecting customers.
  6. well it is only 15 bux and I was wondering, Im going to test one now, and from the info its Princo that makes themw hich gets mixed reviews. But I will probably stick to Ritek which has been pretty reliable for dvd and console.
    Info from DVD:
    ** INFO : Hex Dump Of 'Media Code'-Block Listed Below
    ** INFO : 4-Byte Header Preceding 'Media Code'-Block Discarded
    ** INFO : Format 0Eh - Pre-Recorded Information In Lead-In
    0000 : 01 40 c1 fd 9e d8 52 00  02 d9 0e 10 66 77 70 00   .@....R.....fwp.
    0010 : 03 50 52 49 4e 43 4f 00  04 00 00 00 00 00 00 00   .PRINCO.........
    0020 : 05 cc e8 88 88 80 01 00  06 0c 13 11 77 77 80 00   ............ww..
    0030 : 07 aa 00 00 00 00 00 00  08 01 1b 0d 0f 0d 08 00   ................
    0040 : 09 99 0a 11 0d 5f 00 00  0a 00 00 00 00 00 10 00   ....._..........
    0050 : 0b 00 00 00 00 00 00 00  0c 00 00 00 00 00 00 00   ................
    0060 : 0d 00 00 00 00 00 00 00  00 00                     ..........
    ** INFO : Hex Dump Of 'Control Data Zone'-Block Listed Below
    ** INFO : 4-Byte Header Preceding 'CDZ'-Block Discarded
    ** INFO : Format 10h - Physical Format Information Of Control Data Zone
    0000 : 25 0f 02 00 00 03 00 00  00 26 12 7f 00 00 00 00   %........&......
  7. Banned
    Feb 2005
    USA
    Thanks for the info and the update on media types/codes. I'm planning on buying at least one pack later today.
    PRINCO ? Good lord....
    You know, Verbatim are $15 per 50-pack on sale, and while they'll cost twice as much, twice as many of them will work compared to PRINCO crapola.
  9. Banned
    Feb 2005
    USA
    I got a 25 pack spindle of Staples Branded Princo discs earlier this year that worked great.
  10. I bought Verbatime 16X MIT from them and it throws in freeze at some point even at lower speed so Imagine what the other crap would be. Never had problem with any MIJ like Maxell , Fuji= Yuden
    I have a 100, 50 spindle of -R and a 50 spindle of +r and both are Fuji mid code. Then again, I paid $0 for them too. It is amazing wht people return and then pitch out.
    This is from DVD Decryptor:
    Disc Information:
    Status: Empty
    Erasable: No
    Free Sectors: 2,298,496
    Free Space: 4,707,319,808 bytes
    Free Time: 510:48:46 (MM:SS:FF)
    Supported Write Speeds: 4x
    Pre-recorded Information:
    Manufacturer ID: FUJIFILM03
    Physical Format Information (Last Recorded):
    Book Type: DVD-R
    Part Version: 5
    Disc Size: 120mm
    Maximum Read Rate: Not Specified
    Number of Layers: 1
    Track Path: Parallel Track Path (PTP)
    Linear Density: 0.267 um/bit
    Track Density: 0.74 um/track
    First Physical Sector of Data Area: 196,608
    Last Physical Sector of Data Area: 0
    Last Physical Sector in Layer 0: 0
    I burn them all at 4x so it has been no problem for me.
    Sep 2004
    Tampabay, Florida
    I got 3 (50packs) for only $35.00 from Office Depot last week and they were RICOHJPNR03. I made a burn of the exact same movie on both Verbatim 16x and these. Both came out with a 95% burn quality although the RICOHJPNR03 has slightly more PIF errors.
    When I burned the same movie at 12x the burn quality was only 50%, so it doesn't like the slower burn speeds. I use a NEC 3500 with Liggy & Dee's 2.TG firmware.
  14. Well, my batch sucked.. so Ill return it and just try out Taiyo Yuden -R (100 for 38 bux with free shipping). I always burn at 4x with xb and dvd just so I wont make coasters
    Thanks all for the comments! This site has helped me so much and I knew I would find answers!
  15. Banned
    Feb 2005
    USA
    i bought a pack of these last night. I can't remember the last time I made a coaster until these. three attempts, three coasters. Office max had no questions when I returned them today.
    I don't recommend them.
  16. Im glad they didnt give you a hassle cause mine are going back!
  17. Just tryed a spindle of +R and -R,
    Lets see -R were princo 4X, bottom of the top few disks were damaged...
    The +R were optodisc 4X, 6X and 8X silver top. They both burned Ok once I got past the top few Princo's. My second batch of discs that I bought when I first got the Sony 500A were princo 1X, I just played one of them last week, still OK. 15cents a disc for discs that'll be burned and watched once shortly thereafter, that's OK. I'll still use MIJ for keepers, MIT for Keepers where if they die, Oh well, OM 15centers for one time, time shifting.
