With my new video ipod, I am very excited about playing movies on the TV. The quality is okay, however I really want the best picture possible. My question is with a movie: Red vs Blue Season One. Due the nature of the filming (video capture of Halo 2) there are large black bars on top and bottom BUT IT IS NOT IN WIDESCREEN. The format is 4:3. Instead of wasting those black pixels on my 230401 pixel limit of the ipod, I want to trim the bars from the .VOB files, encode the remaining video to MPEG4 in 16:9, and the have the TV add the black bars back to the image (edit). I plan to use FFMPEG for encoding.
The purpose of this post is:
1) As this will take multiple hours and retrys, do you think it will work?
2) How do I remove the black bars?
3) What is the best possible workflow for this?
Originally Posted by bbt.mr.squishyWant my help? Ask here! (not via PM!)
I would encode to 3ivx MPEG4 using Diva and crop off the black bars. Use a ratio of 640x360 for your newly widescreen video. It will not have sound. To get sound, demux the audio and convert it to AIFF. Open up both video and audio in QuickTime Pro and export to an MP4 container with video set to passthrough.
If you have MPEG Streamclip, all you will need to do is get the crop values from Diva and input those into MPEG Streamclip. Streamclip will encode the 3ivx and audio for you into a .MOV container. You'll be good to go.
Don't waste time with multiple hours and retries. Do short clips of five minutes or less to perfect your technique. Once you have it down, then do the whole movie.
Ripbot264 iPod format will play on iTunes but won't sync to iPod/iTouch?
By Riley007 in forum Blu-ray RippingReplies: 2Last Post: 31st Dec 2010, 00:04 -
File Converted by Handbrake (0.9.3) Using iPod Preset Won't Play on iPod
By GrayStrickland in forum Video ConversionReplies: 0Last Post: 8th Mar 2009, 20:56 -
math problem help?
By lordsmurf in forum Off topicReplies: 4Last Post: 25th Feb 2008, 23:52 -
Math Question Regarding Aspect Ratio
By Krelmaneck in forum Video ConversionReplies: 10Last Post: 28th Sep 2007, 00:08 -
Videora iPod Converter (DVD to IPOD)
By Denman007 in forum DVD RippingReplies: 0Last Post: 15th Aug 2007, 19:06
