does anyone know of any good shareware programs that i can use to convert wmv video files into a compatible format for my ipod video.i know the iod supports several file formats,mpeg 4 being one of them.
Videora iPod Converter
and if it doesn't support wmv, convert the wmv to avi first with something like stoik video converter. -
converted wmv to mpeg4 in 2 passes but cant move the file in itunes or the ipod?ive been trying to drag the file over,is there another way i need to do this?do i have to deactivate DRM rights for the ipod.
Hi,
Are you sure your finished mp4 is within spec for the iPod?? The resolution limits for .mp4 files are 480x480 or 230400 Pixels in total, video bitrate no greater than 2500 kbps and audio no greater than 160 kbps. Try playing your file in Quicktime and choose view movie info from the menu and you can check the specs. -
yes its within spec,managed to transfer in the files eventually.
How to convert any video to MP4 iPod, iPhone, PS3, XboX360 using free tools
By Baldrick in forum User guidesReplies: 74Last Post: 6th Apr 2014, 23:03 -
How can I convert some wmv to mp4?
By Giunaid in forum Video ConversionReplies: 5Last Post: 19th Mar 2010, 05:58 -
Unable to convert some WMV files to Ipod Touch format - Why?
By tradertt in forum Video ConversionReplies: 14Last Post: 8th Oct 2009, 04:22 -
How to convert video to iPod MP4 using MPEG StreamClip (free)
By Baldrick in forum User guidesReplies: 20Last Post: 6th Jun 2008, 22:48
