How do you choose between widescreen and full screen with tmpgenc? If it helps, I'm working with The Mummy Returns. Flask gives full screen, tmpg does wide screen and frankly, it looks funny. When put in player, the movie is full screen.
open up the configuration dialog box.
go to the advanced tab.
and change the source aspect ratio from there. -
forgive me, it's late where i am. i probably read your question wrong.
You want the source correct, but i am guessing you where talking about the output aspect ratio to change that.
open up the config dialog and change the aspect ratio to 16:9 -
The Mummy Returns was released "Wide Screen" and "Pan & Scan". Make sure you have the right release.
dvd2avi->f5
should tell u the source aspect ratio of the movie.
no such thing as 16:9 fullscreen, so if the dvd is fullscreen, then it's 4:3.
however, widescreen dvds can be either 16:9 or 4:3. this is where dvd2avi comes in... -
Set the encoding according to what your movie is, if you try settings a Wide Screen for a Full Screen movie, the people will appear a bit on the heavy side
And If you set a Wide Screen movie to Full Screen, it will appear as if they are anorexy and extremly tall
In your case, I believe you simply took the Full Screen version of the movie, instead of hte Wide Screen, I did the same mistake with The Grinch, grrr.. yuck!
Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician.
Full Screen Ripped DVD is not Displaying Full Screen on Widescreen TV
By jgciamarra in forum DVD RippingReplies: 3Last Post: 23rd Jan 2012, 18:42 -
Windows Media Player 8 full screen DVD playback not full screen
By brassplyer in forum Software PlayingReplies: 1Last Post: 3rd Jan 2012, 16:43 -
Blank screen when playing video on 'full screen'
By RAYPEV in forum Newbie / General discussionsReplies: 6Last Post: 4th Aug 2011, 20:40 -
DVD Lab Pro, help mixing full screen and wide screen.
By stantheman1976 in forum Authoring (DVD)Replies: 4Last Post: 31st May 2009, 18:23 -
How can I convert a widescreen movie to full screen movie on PSP?
By VidHunter in forum MacReplies: 2Last Post: 9th Nov 2008, 23:20
