I'm wondering whether anyone here has experience with the Cyberlink DVD solution package.
http://www.cyberlink.com/multi/products/main_33_ENU.html
Anyone have any problems with this? The price seems pretty good!
Yes ... just got this with a new dvd burner from lg , and already played with it ... no , no restart , I just want to go now .
Anyway , for what its worth as an all-in-one type package , its not too bad ... freeware still kicks butt though .
The only bad thing about it is sp and lp modes , if you use them , you'll be waiting quite a while for them to finish even a half full dvd .
I can do the lp and sp modes much faster using freeware .
As for it's ability to provide good dvd burning , as yet untested , but would recommend imagetools , should burning be unsuccessfull using the programs default burning engine .
playing dvd on pc via cyberlink 7
By pjblevin in forum Software PlayingReplies: 0Last Post: 20th Nov 2008, 14:02 -
Lost Cd to play dvdfilms after i have installed powere dvd cyberlink
By chikenkat in forum Authoring (DVD)Replies: 0Last Post: 12th Aug 2008, 18:36 -
I have a question about cyberlink powerdirector 6.
By ingeborgdot in forum Authoring (DVD)Replies: 4Last Post: 3rd Nov 2007, 21:31 -
Cyberlink Director
By micromack in forum Authoring (DVD)Replies: 1Last Post: 1st Jun 2007, 16:38 -
Cyberlink PowerDirector 6 - DVD starts playing after 8 seconds
By gayclarke in forum Authoring (DVD)Replies: 1Last Post: 24th May 2007, 00:00
