I've been (attempting to) capture my VHS tapes and export as divx avis using the Pyro A/V Link and Toast 7.
I’ve been trying to capture from a Sony VHS player. Somehow signal stops occasionally causing my software to stop capturing.
I would say I have about a 25% success rate on my attempts. Ie. 3 times out of 4, the capture stops.
(Always at a different spot too, and with different VHS tapes)
When I use other software to capture (Final cut pro) it allows me to ignore dropped frames, but warns me I’ve got dropped frames and I’m concerned because I don’t know how many or where. Also Final Cut Pro isn’t as convenient for my purposes.
Previously I was using a Canopus ADVC 100 I had borrowed from work. It never had this problem.
If you have any suggestions, I’d love to hear them.
Thanks, SDM
I have had that problem too with a recording of a TV show on a non-commercial tape (meaning the tape was recorded by a person on his home deck not by a company as a made-for-sale item). One alternative would be to record until it stops then restart from the spot where it skips and stitch them together in iMovie. Takes a lot of patience though...
Merlin Macuser
Ann Arbor, MI -
Keep the Pyro cool. Make sure it has good ventilation under the box. A trick my brother used was to put it in the freezer for awhile before using it. But those boxes have a problem with dropped frames. Canopus is far superior.
Also, you don't say what you're using for the capturing application. Try the freeware Vidi.
You also might consider using a DV camcorder that has Firewire pass through or getting an EyeTV 200 to do your capturing. -
Interesting.... I'll try keeping it cool and ventilated first.
Yes I discovered Vidi yesterday. It seems pretty good, and it seems to just keep on capturing even if the tape is crappy (which some of them are)
I was using toast 7 for the .dv capture and divx export from there. Or FCP if I need to do any edits.
Thanks for the suggestions.
-- sdm.visit my photo retouching website: http://www.shiftstudio.ca
ADS Pyro A/V Link - Firmware u/g to fix VHS dropped frames
By pbanders in forum Capturing and VCRReplies: 16Last Post: 24th Mar 2011, 22:40 -
ADS Pyro A/V Link - black screen
By Brad in forum Capturing and VCRReplies: 10Last Post: 20th Oct 2010, 19:23 -
No comunication between Protools and ADS Tech PYRU A/V Link video converter
By soin in forum Software PlayingReplies: 0Last Post: 12th Jul 2010, 17:03 -
Anyone watch ads? They have gone high tech.
By edDV in forum Off topicReplies: 8Last Post: 18th Apr 2010, 15:49 -
Component video capture with PYRO A /V Link?
By theinv in forum Capturing and VCRReplies: 2Last Post: 19th Sep 2007, 17:47
