I have never researched stand alone DVD recorders until now, and only because my partents would like one for x-mas. My simple question is when using a standalone DVD recorder are you restricted to 60 mins of video per DVD-R/RW?
No, but just like vcr tapes, as you increase recording times, you DECREASE the recording quality. As a result, I NEVER go beyond 3 hrs. on a disc.
No.
He's a liar and a murderer, and I say that with all due respect. -
Most any DVR will give you options for 2, 4, 6, 8 hours or even longer.
Here's a link to a FAQ about DVRs :
http://hometheater.about.com/od/dvdrecorderfaqs/a/dvdrecfaqintro.htm
Most have tuners and you hook your cable TV through them and use them about the same way you use a VCR. The ones with the hard drives on board are well worth the extra cost. You record to the hard drive and just make DVDs if you want. Much more versatile.
I would read the reviews for the models you are interested in. Some are fairly easy to operate and a few are difficult, with a steeper learning curve. The ones with a built in TV guide sort of selection are popular and make programming easier. It make take a bit of research to find one that suits the way you want to use it.
Advice for simple, free video-editing software for a newbie
By belltown in forum Newbie / General discussionsReplies: 3Last Post: 4th Sep 2011, 22:25 -
AviAddXSubs simple question (hopefully!)
By vladman2nd in forum SubtitleReplies: 1Last Post: 8th Jul 2008, 01:01 -
Simple Mplayer Question
By Maikeru-sama in forum Newbie / General discussionsReplies: 6Last Post: 29th May 2008, 21:10 -
question about how to remove simple software
By jimdagys in forum ComputerReplies: 2Last Post: 10th Apr 2008, 11:15 -
Simple Question: True or False?
By jcm0320 in forum Capturing and VCRReplies: 10Last Post: 23rd Aug 2007, 22:33
