Hi
since there is not software like anydvd for the mac, I was wondering if anyone knows a firmware which patches my LaCie (NEC ND-3540A) region code free?
I have never done this on a mac nor do I know where to get a firmware patch from.
Can anyone please help?
thanks in advance.
Results 1 to 11 of 11
Get the region-free patch listed for your drive from RPC Firmware page,
and then use BinFlash to install it,
and then Region X to verify it."Everyone has to learn, so that they can one day teach."
When I'm not here, Where can I be found?
Urban Mac User -
The problem is: I do not know where the firmware is on that site.
The only firmware I find is 1.F1 (Mad Dog OEM) for RPC-2
Can anyone confirm if this is a region free firmware for my burner?
also: can you give me a step to step instruction for patchin the drive with mac? -
If you click the DATE link
(16/10/2005), it will take you to the page.
clikc on the name of your drive,
and it will take you to mad dog's link.
As for instructions,
go here at Xlr8yourmac
and read the instuctions FULLY, it should help you."Everyone has to learn, so that they can one day teach."
Urban Mac User -
I find it easier to use NecFlashX to flash my NEC drives. It's a GUI built around Binflash. It’s easier to point and click than type commands. I find it best to run it from the desktop. Also, don't have more than one NEC drive connected at a time when you do the flashing. You can find NECFlashX at:
http://www.ralf-papenfuss.de/mac/necflashX.html
As far as modified firmware goes, I have had a good experience using Liggy & Dee's modified firmware. You might try Dee's 1.W8 RPC1 firmware. It incorporates enhanced writing strategies, rip lock removed, and region free.
http://liggydee.cdfreaks.com/page/3540/ -
I checked out the page http://liggydee.cdfreaks.com/page/3540/
looks pretty good.
I have an RPC2 NEC drive. which one should I download now for flashing? Can I use the RPC1 one?
what's the difference between the "FAST SLOW ORIG And RPC1" ???
thank in advance -
got the RPC1 since this is the regionfree one (I found out).
Tried to flash it with neoflashX but it took about 30 mins and in the end it said something like:
entering safe mode
error flashing
and some hex codes
Can anyone help?
I used the firmware off the http://liggydee.cdfreaks.com/page/3540/ site.
The RPC1 Version Dee's 1.W8 firmware.
Any suggestions please? -
sounds either like:
you'll have to do a force firmware accept
or
your Firmware choice isn't compatible with the drive.
Maybe now you'll give my posts and BinHex a try...?
certainly can't hurt...and is easy as pie...."Everyone has to learn, so that they can one day teach."
Urban Mac User -
uhm. I don't understand a single thing LOL
sorry...
Do you think I should try the maddog version? is it regionfree? -
I've never had a problem with NecFlashX. To be sure though, you have to launch it from the desktop. You can't run it from the applications folder or a different drive. Your firmware choice sounds okay.
Well it didn't work.
Flashed about 30 mins and stopped with an error.
Luckily my drive still works.
Will try the maddog firmware later this day.
Until then, can you, terryj, please explain what you mean by your last post?
Maybe you have dealt with my problem before?
thank to everyone helping me. Very kind
Hack working for Sony BDP-S380 region 1, to make it region free?
By Julieso in forum DVD & Blu-ray PlayersReplies: 0Last Post: 30th Dec 2011, 17:12 -
Ripping a Region 2 DVD on a Mac Book Pro with Mac The Ripper
By Jess021 in forum MacReplies: 7Last Post: 17th Nov 2011, 06:04 -
Klipsch CS-500, need to make region free / code free / zone free
By Trialsman in forum DVD & Blu-ray PlayersReplies: 1Last Post: 28th Nov 2008, 14:16 -
Sony DVP-FX720 region restriction - using DivX waiting for region free code
By wig in forum DVD & Blu-ray PlayersReplies: 1Last Post: 27th Aug 2008, 05:34 -
How to Make a Pioneer DVR-520H Region 1 a Region Free player?
By Ossocao in forum DVD & Blu-ray RecordersReplies: 3Last Post: 26th May 2007, 22:35
