I'm having trouble creating QT compatible video with mencoder and x264/faac. I think I'm very close, though - video plays perfectly, but audio plays for random split second durations throughout playback.
I am doing this COMPLETELY via commandline because I want total control over my filtering and encoding options. (ffmpegX is too limited for my taste.)
For my tests, I've been using the default x264 options (specifying only bitrate - so no bframes, 8x8dct, etc, that QT doesn't like). Commandline:
The closest I've gotten to QT compatibility for audio is:Code:$ mencoder input.avi -o output.264 -of rawvideo -vf-add harddup -ovc x264 -x264encopts bitrate=1000 -oac copy -frames 3000
I then combined the two streams into a .mp4 using mp4creator:Code:$ mencoder input.avi -o output.aac -of rawaudio -vf-add harddup -ovc copy -oac faac -faacopts br=128:mpeg=4 -frames 3000
QT opens this file, and plays the video flawlessly, but the audio skips in and out. mplayer, on the other hand, has absolutely no problems with this file.Code:$ mp4creator output.264 -r 29.970 final.mp4 $ mp4creator output.aac final.mp4 $ mp4creator -list final.mp4 Track Type Info 1 video H264 Main@5.1, 100.133 secs, 990 kbps, 640x416 @ 29.970140 fps 2 audio MPEG-4 AAC main, 99.882 secs, 125 kbps, 48000 Hz
Any tips?
Are my mencoder lines bad?
Is there an additional mp4creator step?
Can I get faac to do CBR? (Does it matter?)
I've read the guide over at doom9, so apparently the Windows folks can do this. <http://forum.doom9.org/showthread.php?t=102609>
If necessary, I can provide sample files of the results. The source, however, is raw yv12 - much too large to transfer.
Results 1 to 1 of 1
TX264 0.9.7 - GUI for x264 with audio encoding support
By ozok in forum Video ConversionReplies: 4Last Post: 27th Jul 2013, 20:12 -
question. FAAC or MP3 lame for videos
By llmercll in forum Video ConversionReplies: 4Last Post: 1st Feb 2009, 22:05 -
MP3 (LAME), AAC (FAAC) and AC3. Can we rank them?
By moiz in forum AudioReplies: 3Last Post: 17th Oct 2008, 14:57 -
ffmpeg faac frame decode failed
By fobster in forum Video ConversionReplies: 2Last Post: 28th Mar 2008, 07:10 -
TMPGEnc Xpress, MainConcept, H.264 and QuickTime Compatibility
By PuzZLeR in forum Video ConversionReplies: 6Last Post: 27th Oct 2007, 04:05
