Is there an automated way to demux the audio and video stream from an avi?So far i've been opening the avis on vdub mod,demux the audi stream and then save the avi as a no sound one to get the video.But that's time consuming!
Isn't there a way to get the video and audio from avi,muuch like we do from mpg.Just select an avi source click start and get the streams?Like the mpeg tool of tmpegenc does for mpeg-2?
Results 1 to 27 of 27
There's documentation for the CLI of AviDemux on the AviDemux site. A brief glace makes me believe it's only possible to demux audio and raw video stream (without AVI container).
Of course a GUI could be created, but a pretty simple bat script could be easily written to process let's say all AVIs in a given directory.
/Mats -
What extension would th raw video have?
Can you help me with the command line editing?How could i process a whole folder? -
Don't know, really, what the raw video stream would appear like - ".XviD" for a XviD stream? OTOH, the extension isn't what matters - what matters is what tools accept raw video stream.
What do you intend to do with the demuxed streams?
Example of bat script:
This should demux all AVIs in current directory to elementary streams.Code:for %%A in (*.avi) DO avidemux2 --load %%A save-raw-audio save-raw-video
Not sure, but you might have to split the audio and video saving in two operations.
/Mats -
I'm using megui to encode avc for psp and it encodes audio and video seperately.
So i need to have a soundless video as a video input and seperately the audio as the audio input in order to encode.
Also since psp only supports 29.97 i need to use besweet on the audio to stretch it to 29.97 and convert with vdub the video to 29.97.
So in other words i need a quick way to seperate the streams from avi files!
Now as for avidemux i asked the extension of the raw video so i would know what to use on the cli.I have no experience with cli whatsoever,but looking at the site i created this one:
avidemux2 --load input.avi --save-raw-audio --save output.avi
avidemux2 --load input.avi --save-raw-video --save output.mp3 --quit
Is that correct?Or should i use yours instead?So i write this in notepad,save it as bat and run it right? -
Yes, you just write in Notepad, and save with a .bat extension.
As for your examples - may very well work. I'm just theorizing, as I haven't avidemux on this 'puter.
Experiment!
/Mats -
None of the two worked.Then i tried your script for mplayer only i edited a line so i can have seperate outputs.
mplayer -dumpaudio -dumpfile out.raw foo.avi
mplayer -dumpvideo -dumpfile out2.raw foo.avi
And it gave me out.raw and out2.raw.
I opened out.raw (audio) in foobar to test it,but it couldn't decode it.
Then i put out2.raw (video) on mpc but it couldn't play.When i scrolled thorugh the status bar it displayed some frames which were in bad condition,but there was no playback.
So any other suggestions?I spose raw statre of the streams won't cut it. -
Tried:
...and it worked beautifully. I checked the audio format first with GSpot.Code:avidemux2.exe --load "d:\movies\xyz.avi" --save-raw-audio xyz.ac3
Check stdout.txt for hints on where your process fails. AviDemux seems picky - some AVI's I tried, it failed after a few minutes of the source.
/Mats -
No, because the video will not be an AVI anymore - just the raw video stream. Unless it's mpg, it's pretty useless. Or maybe, as XviD/DivX is mp4, saving as MP4 will do it? Gotta try! Nop, no dice. "Nothing" seems to rcognize the raw video.
/Mats -
Ok lets recap,tha audio works,so how can i make a batch to extract the audio of all avi files in a directory and save them as their avi name.
So i have a folder with files 1.avi 2.avi 3.avi and i get 1.mp3 2.mp3 3.mp3.
And then as for the video,how can i make vdub process a batch of video files with the settings i choose?So i can save a settings file where i have selected no sound,and frame rate conversion to 29.97.How can i make that apply to a number of files? -
I tried that code but it didn't work.I had two avis on the folder,but i didn't get anything back.
This is the exact command I've just succesfully run. CD to the dir where your AVI's are, and change "k:\Program\avidemux\avidemux_2.0.40\avidemux2 .eCode:
for %A in (*.avi) DO "k:\Program\avidemux\avidemux_2.0.40\avidemux2.exe" --load %A --save-raw-audio %A.mp3 --quit
xe" to whatever full path to avidemux2 you have on your system.
/Mats -
Nope. Looks exactly like mine. ...and you "are in" the directory where the AVI's are?
/Mats -
Of course i am,and i don't get any file after i run the .bat.
So yours run succesfully though? -
Yep. Only drawback is that it at once launced one instance of avidemux for each AVI, resulting in long extraction times. I'm sure there's a way to launch AviDemux and have the bat script wait for completion before stepping thru to the next iteration, but that's beyond my relatively limited bat script experience, I'm afraid...
As for why you don't get any output - I'm at a loss! What if you just change all after DO to "@echo %A" (just prints out the file names) - do you get anything? (Just to see if it's the loop, or in the Avidemux stage things go wrong)
/Mats -
/MatsCode:
for %A in (*.avi) DO @echo %A
What do you mean? Ah - you run the bat by clicking on it!
Work from within a "DOS box"! Otherwise, you don't know what "working dir" is.
Put all AVIs and the BAT script in one dir.
Open a "DOS box" and change to that directory.
Type the name of the bat script.
/Mats -
What's the difference between clicking on it and calling it from ms dos?Anyway let me try that as well.
EDIT:Tried it,still nothing happened.
C:\>cd Documents and Settings\Administrator\Desktop\New Folder (2)\avidemux_2.1.0_win32\avidemux_2.1.0
C:\Documents and Settings\Administrator\Desktop\New Folder (2)\avidemux_2.1.0_wi
n32\avidemux_2.1.0>a.bat
\Documents was unexpected at this time.
C:\Documents and Settings\Administrator\Desktop\New Folder (2)\avidemux_2.1.0_win32\avidemux_2.1.0>for \Documents and Settings\Administrator\Desktop\New Folder
(2)\avidemux_2.1.0_win32\avidemux_2.1.0\avidemux2.exe" --load A.mp3 --quit
is there a way to do batch demuxing of avi files in virtualdub?
By Ankin in forum Newbie / General discussionsReplies: 1Last Post: 16th Oct 2009, 08:44 -
Automatic cropping
By didikai in forum Newbie / General discussionsReplies: 0Last Post: 6th Dec 2008, 10:20 -
Invoke Automatic IVTC!?!
By Alexstarfire in forum Video ConversionReplies: 2Last Post: 8th Sep 2007, 07:56 -
Automatic updates?
By fLYtRap in forum ComputerReplies: 11Last Post: 13th Jul 2007, 16:46 -
Automatic Shutdown
By borisblavasky in forum ComputerReplies: 10Last Post: 12th Jun 2007, 14:13
