I am using Ulead Video Studio to edit my MPG's. Should I be setting my Frame size to 352x240, 352x480, 704x480 or 720x480. I want to ultimately author these MPG's into a DVD to play on a normal DVD player. Any info would be great!
Hi bowmah,
All the resolutions you list are valid for NTSC.
However, it all depends on the resolution of the MPG's you're working with. Use GSpot (v2.52 beta) to get the resolution - once known, use the same. If they're different, go with the smallest one.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
You can right click on the source clip in UVS to get the properties. Match everthing for your final output (except the audio, chane to Dolby Digital if you have the plugin). This will do two things, maintain the quality of the video that you have not edtited since UVS will only reencode the parts where you have edited like transitions and second it will speed up the encoding process condsiderably.
As a general rule, if your source files isn't in one of the formats you mention to start with, best is to resize down to the closest of those. Resizing up is never a good idea.
Also, the lower the resolution, the lower the bitrate can be used, ultimately enabling you to put more material on each disc.
/Mats -
Awesome stuff! I just right clicked on the properties and it shows that my dumped files are 720x480. I will be sure to output to this size as well.
Thanks everyone!
Frame Size
By kamranj in forum Newbie / General discussionsReplies: 18Last Post: 9th Jan 2011, 19:59 -
Frame Size. What effect does it have?
By happydog500 in forum Capturing and VCRReplies: 7Last Post: 12th Mar 2009, 01:21 -
Frame size in HDVSplit
By kippard in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 5th May 2008, 01:36 -
Video frame size
By DuBsTaR in forum Newbie / General discussionsReplies: 2Last Post: 18th Mar 2008, 20:35 -
How to alter frame size?
By elite123 in forum Newbie / General discussionsReplies: 4Last Post: 20th Aug 2007, 19:43
