I just completed a complilation & burn of 38 cartoons (4.28 G) using Version 2
(18 November build). It was burned on a 8X DVD+R disk manufactured by MCC with Book Type set to DVD-ROM. The Play All button is unresponsive and it will not play past title 36. All others play properly on WinDVD6.
I've had this problem on the first V.2 builds but thought it may have been corrected.
Will have some dual core CPU data for you after the first of the year.
Tom
The maximum number of buttons allowed on a DVD menu is 36 (according to the DVD specs)... I shall add a warning to this effect.
MultiavcHD menu problem...HELP!
By digitalfreaknyc in forum Authoring (Blu-ray)Replies: 7Last Post: 12th Jan 2012, 07:06 -
Menu problem in Architect 5
By targa912 in forum Authoring (DVD)Replies: 0Last Post: 11th Feb 2011, 21:22 -
ever had this menu authoring problem before?
By uglijimus in forum Authoring (DVD)Replies: 5Last Post: 22nd Oct 2009, 15:06 -
DVDAuthorGUI: Menu problem
By videohalp in forum Authoring (DVD)Replies: 5Last Post: 20th Aug 2008, 22:11 -
Menu Problem - Skipping
By vinnyv07 in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 30th May 2007, 20:17
