ok so ill just say everything im trying to do, so ive backed up dvds on my computer and have the iso files. the isos work, if i mount them in daemon tools, they work with no problem, but once I open decrypter or imgburn and try to burn it i get problems. so i open whichever program, insert my dvdrw in the dvd burner, go and select the file to burn, make sure its harddrive to dvd, and then i hit burn. on each program it says the disc needs to be formated, or erased, same thing, so it does that. then when thats done i get this error. same on both program, at same time
Results 1 to 10 of 10
other rips ive done of my dvds that have been in img format have worked
im using dvd+rw, is this the problem? -
Originally Posted by PissedPantherIf in doubt, Google it.
yeah i tried multiple isos, and made numerous copies..
i did find that i go through the process i stated above, and get that error, if i leave the dvdrw in the drive, and dont close the program, and change the iso and try again, it works, well atleast twice it did. but when i try to run dvd in power dvd i get this error
That "auto-resume thing" is fine and is not really a problem. All that does is remember what point you were up to last time you played that DVD. If you don't want to see it then tick the "Don't ask me this question again" box and it will go away ..... forever.
If in doubt, Google it. -
haha ok, well ignore those posts then
but still im trying to figure out this error, have you seen it before? or know what it means?
Error when burning to DVD with ImgBurn
By drkzero in forum DVD RippingReplies: 13Last Post: 4th Feb 2012, 19:07 -
I/O errors using ImgBurn and DVD Decrypter
By jcsdmd in forum Newbie / General discussionsReplies: 16Last Post: 27th Aug 2011, 14:58 -
Decrypter to Shrink to Imgburn?
By visionman in forum DVD RippingReplies: 3Last Post: 19th Jan 2011, 12:06 -
DVD Decrypter error
By turbochargedRS in forum Authoring (DVD)Replies: 3Last Post: 12th Mar 2008, 19:08 -
Burn audio CD with ImgBurn and DVD Decrypter - not enough space
By theWallflower in forum AudioReplies: 11Last Post: 7th Aug 2007, 15:21
