Hi,
I went through the unfortunate expense of trying the unreliable RiData DVD+R DL inkjet prinatlbe set of 25. I got 6, 7 coasters, but some discs play sometimes fine, other time they do not.
I notice everyone raves about Verbratim. That's good, but the only inkjet printable ones are $80 for 20-pack on Newegg, which seems a bit too much.
Is there a happy inbetween medium, any other inkjet prinatable brand that is not wicked expensive?
As I type this response, Supermediastore has a sale on the Verbatims (the same white inkjet printable dual layer DVD+R discs). It does involve a rebate, but if you do not mind putting up with that, they are only $2.99 per disc.Originally Posted by pred02
The current sale price is $59.80, with a $35.00 rebate. Important: Note that this deal has free ground shipping, so the final cost (after the rebate) would truly be only $2.99 per disc. I consider that a terrific price for these discs -- I paid almost $1.00 per disc more only a few weeks back. These are the same 20-packs you wrote of above, in a cake box. I have used these discs and I have found them just as reliable as the non-printable Verbatim dual layer discs (I have now burned 16 of these printables, and have had no coasters at all).
Hope this is of some help,
-Bruce -
I've got some printable Ricoh's on the go at the moment, and they seem OK - can't advise you on where to buy as I'm in the UK.
This is the best deal I've found so far for the DL Verbatim printables. Too bad there is a limit of one. I just received my order last week and sent in the rebate. A month or two ago someone else (either NewEgg or Meritline I think) had a similar deal - $2.99 after a $30 rebate. That was the fastest rebate I've ever received. The check came in lass than a week.Originally Posted by BSpielbauer
Anyway, these are great disks and this is the best deal I've seen on them so far. I do wish they'd make a hub-printable version though.
Templates for popular printable DVD media
By stiltman in forum MediaReplies: 60Last Post: 4th Jan 2011, 09:20 -
looking for silver hub printable DVD media
By PharmBoy in forum MediaReplies: 6Last Post: 30th May 2008, 06:31 -
Need recommendation for printable media
By fazza8 in forum MediaReplies: 0Last Post: 23rd Nov 2007, 16:10 -
Taiyo Yuden 16X Water Shield White Inkjet Hub Printable DVD-R Media
By mn072065 in forum MediaReplies: 66Last Post: 28th Sep 2007, 11:29 -
Best Printable CD media
By r00kie in forum Newbie / General discussionsReplies: 4Last Post: 9th May 2007, 20:39
