I'm going to make a film with both slow motion, and a "fast motion" effect. My camera has 1/60 and 1/1,000 as the highest and lowest shutter speeds. Will using those improve my ability to alter the speed of the footage (which will mostly bedone in post)? I've heard of this, but I don't know if these are low/high enough, and I'm not sure which speed to use for slow and which for fast.
Hi ShBm,
I too have a cam where the shutter speed can be changed, and I too wondered if I'd be able to shoot normal speed events with a high shutter speed and hence, on playback, effect a slow motion look.
My experiments, however, revealed that the cam still recorded in 25fps (I've got a PAL cam) - meaning that the shutter speed seems to have no effect on the framerate that the cam records at.
The only thing I could conclude was that the shutter speed controls how much light comes in - a faster shutter speed for brighter conditions.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
Your shutter speed won't get you the final outcome you're looking for...
All it will do is allow for clearer "frame to frame" motion with fast moving objects..But if you use a slow shutter speed, then images tend to look blurry...
I don't know how much you know about cameras or post editing, so i'll just suggest to stay in auto exposure mode, and pick the settings that you're working with (ie dark,spotlight,outside,snow conditions, etc...).
On the good side, most advanced NLE's allow for slowing and speeding up footage, and do a good job of it. Just make sure your footage is clean to begin with..
Rolling Shutter and Deshaking
By blewyn in forum EditingReplies: 8Last Post: 5th Feb 2012, 16:45 -
How to calculate rolling shutter percent
By zzyzx2 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 28th Jul 2010, 00:41 -
Options for continuous high-speed recording?
By dbooksta in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 11Last Post: 9th Apr 2010, 12:36 -
Shutter speed settings with TL-light
By B-Twien Bytes in forum Newbie / General discussionsReplies: 0Last Post: 17th Mar 2010, 04:09 -
Hi-Speed camera
By garman in forum EditingReplies: 11Last Post: 6th Nov 2008, 19:56
