    May 2004
    I'm enjoying my digital cable, but I'm thinking I would be better off with dish. However, I've got a good deal on cable (half price for the first 6 months) for right now, so I can bide my time a while and wait.
    Considering that both Dish and DirectTV are apparently migrating to MP4 for video compression sometime next year, and as consequently all set-top hardware currently in place will need to be upgraded, I'm wondering if it would be best to get a dish now vs. later.
    In other words:
    A) Do you think it will less expensive/less trouble (with changing hardware, etc.) to wait and "go dish" after the migration? OR ....
    B) Do you think, after incurring what is sure to be a big expense by migrating to MP4 and upgrading everyone's hardware (which I'm told both networks are going to do), and with the additional channel offerings resulting from greater compression, that satellite might actually become more expensive after MP4 is used? And therefore, should I maybe get dish sooner rather than later and get "grandfathered" in at a lower rate?
    I'm leaning towards just waiting, obviously. Anyway know a definite timetable on this change? I've heard it's going to be in 2006 for sure, but I'd like to read something more definitive.
    -abs
    "The purpose of art is not the release of a momentary ejection of adrenaline but rather the gradual, lifelong construction of a state of wonder and serenity." --Glenn Gould
  2. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    They will be rolling out by local market.
    You will find lots of info and opinion here
    http://www.avsforum.com/avs-vb/forumdisplay.php?f=25
    http://www.kiva.org/about
  3. Member Conquest10's Avatar
    Chicago, IL
    But, if you buy all the hardware now, won't you be SOL when they switch? You would have to buy it all over again. Won't you?
    His name was MackemX
  4. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    With DirectTV, you own the equipment, so I don't know how the upgrade will work, most likely it won't be free.
    With Dish Network, you are using their hardware, so I would expect they will replace old hardware as needed.
    Google is your Friend
  5. Member edDV's Avatar
    Mar 2004
    Best not to be on the bleeding edge on this one, especially if buying equipment.
    Aug 2004
    Midwest, USA
    DirecTV is indeed upgrading to Mpeg4 by market area. Originally they had told subscribers that existing HD subscribers would be upgraded for free to the new Mpeg4 receivers
    I've read from subs in the first few markets that DTV is charging $99 to upgrade the dish and receiver (a new 5 LNB dish is needed to see the new satellites).
    This forum has some great info regarding all HD providors, sat & cable:
    http://highdefforum.com/
  7. I think the roll out will continue into 2007 and what they are converting over first and formost is local HDTV channels that's why they are doing mp4. You can buy a cheap used DTV receiver for probably $50 or less. Radio Shack has some good offers for leasing Dish. I doubt that they will eliminate the main channels from mp2 for some time. In fact I think DTV and Dish both offer a mp2/mp4 receiver now.
    If you feel adventurous, you could look into a Free To Air satellite receiver like the Pansat 3500. Here's a forum for more info.
    http://forums.al7bar.tk/index.php
