When I fsatforward my vcd more than 1x the screen cuts in half and I get all this digital distortion mumbo jumbo on the right side and it dosen't go back to full screen unless I restart the whole thing, is there a file or something I need in order to fix this so it will allow me to fast forward?
Thanks a million,
Sid
Well, it depends... If you download a vcd off the net like say a movie, the rippers rip it to VCD compliant, so your DVD Player will recognize it as a true VCD, on the other hand, if the file was converted to VCD in a speical way or maybe its functions arent working porperly, then the true fact may be that your "VCD" isnt really a vcd, to be honest with you, its gotta be your DVD player, no doubt about it, and there is nothing that anyone can do, either buy a new dvd player or deal with it lol....ok well sorry to break it to you but someone had to, k bye
Thanks a million,
Sid
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
spend 5 quid buying a pressed vcd from eureka movies.
If it still does it it's the player - if not it's your discs.
5 quid is cheaper than a new player.
Dave
VCD to VCD back-up
By fiiido in forum Authoring (VCD/SVCD)Replies: 4Last Post: 29th May 2011, 11:39 -
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 06:54 -
Convert NTSC AVI, DVD, (S)VCD to PAL DVD, (S)VCD
By scratchman in forum User guidesReplies: 14Last Post: 4th Jun 2007, 01:36
