    Aug 2005
    Toronto, Canada
    So this happened to me and you guys probably know whats up. I open an xvid encoded .avi file in QT, and the video plays fine, but there is no audio. So i continue on and try to make a DVD out of it, using Toast Titanium 7.
    Same thing when I view the dvd...no audio.
    Anybody know how to make this work properly in QT, or how to create a proper DVD out of it?
    USA
    I don't use my Mac much for video work, but I suspect the Xvid audio may be MP3 VBR or even AC3 which can cause problems for MPEG encoders. There should be a Mac program to identify the Xvid audio format.
  3. Explorer Case's Avatar
    Feb 2004
    Middle Earth
    What does VLC tell about the audio stream?
    Aug 2005
    Toronto, Canada
    the audio stream is:
    codec: a52
    channels: 6
    sample rate: 48000
    bitrate: 284
  5. Mod Neophyte redwudz's Avatar
    USA
    Looks like AC3 audio.
    http://shep.thefridgeowl.com/a52codec.php
    For a DVD, can you encode just the video? Save out the audio from the Xvid as AC3 and put it back in when you author the DVD?
    Aug 2005
    Toronto, Canada
    Anybody want to show me how to do this...author this dvd. Step by step?
  7. Explorer Case's Avatar
    Feb 2004
    Middle Earth
    Updated QT AC3 decoder should help QuickTime and Toast read the audio.
