alright i don't know how to explain this.
I was putting together a video for my grandmothers 80th birthday party..pretty straightforward..just some video taken from the event and a slideshow i made previously. authored it and tested it in my standalone dvd player. I was having problems this morning with the burner though..it would keep spinning down and failing on rw's and even on one dvd-r but then it seemed to start working again..i cranked about 5 out then it failed on another. When checking the stats it said there was a power calibration error.
I did some research and updated the firmware, tried cleaning out the drive and even hooked it up in another computer. Now when I put these dvd-r's i just burned in the drive it says it's a blank cd! I thought ok that's weird..the drive must really just be on it's way out. but then i took it to our laptop dvd drive and it says the same thing! It says the media is blank or invalid. When I put it in my standalone dvd player however it comes up and works fine....any explanation for why this might happen?
the dvd was authored the same way i always author them...
It sounds like it is time to replace the drive.
Believing yourself to be secure only takes one cracker to dispel your belief.
Burned DVD Plays On Laptop, LG Player; Does Not Play On Panasonic Player
By Valentin in forum Authoring (DVD)Replies: 15Last Post: 18th Jul 2010, 13:55 -
Multiple avi movies on one dvd......portable dvd player that plays it?
By 9tinyfingaz in forum DVD & Blu-ray PlayersReplies: 15Last Post: 6th Jul 2009, 04:56 -
Would this DVD player play AVI files burnt onto a blank DVD/CD?
By jane2 in forum DVD & Blu-ray PlayersReplies: 9Last Post: 20th Apr 2008, 20:38 -
Got a DVD plays correct, copies correct but refuses to write on a blank DVD
By cemman in forum Authoring (DVD)Replies: 16Last Post: 21st Jul 2007, 16:09 -
DVD Audio Plays On DVD Software But Not On Windows Media Player 11
By CurtisMinBC in forum AudioReplies: 2Last Post: 29th Jun 2007, 13:39
