or do i need a disc for each .bin?
Basically, yes, since a BIN is an image of one disc.
However, you could mount each BIN with daemon tools, then combine them (using DVDShrink) to ine DVD. The procedure would be exactly the same as to merge 2 DVD discs to one DVD.
So, you can't merge the BIN's, but whats inside the BIN's.
/Mats -
ok so i mounted all three .bins in daemon tools and opened dvd shrink
when i mount them i folder comes up with like 5 folders and had some files in each, but when i go to open the folder from dvd shrink there are no files, after i mount all three bins, what do i do to combine them, ive looked for a guide but havent found one -
What's inside the BIN's? Like I said, a BIN is just an image of a disc, and like a disc, can contain anything. I was presuming they where images of Video DVD discs - but that was perhaps jumping to conclusions?
/Mats -
ok these are the folders and files inside the bin first is the folder then after that are the files within the folder
cdi
ext - lot_x.vcd; psd_x.vcd
mpegav - avseq01
segment
vcd - entries.vcd; info.vcd; lot.vcd; psd.vcd
and it looks like the other two bins contain the same layout
i have three bins tryin to burn to one disc
thanks for the help btw look forward to your reply -
Those a VCD images. Mount with daemon tools, and follow some VCD to DVD guide found left.
Basically, extract the mpg from the VCD's with VCDGear, then just author the ectracted mpg's with TMPGenc DVD Author.
You'll be able to fit 6-7 of these to a DVD.
/Mats -
Hmm... Yes, eve tho there was a while since for me too, I think you're correct!
No need to mount the images before running them thru VCDGear.
/Mats
Newbie Conversion questions: combine multiple .m2ts files
By Deku Scrub in forum Blu-ray RippingReplies: 10Last Post: 30th Aug 2013, 19:58 -
Convert AND Combine Multiple VCD DAT files to Single Divx/Xvid file
By GrayStrickland in forum Video ConversionReplies: 4Last Post: 17th Aug 2012, 13:23 -
burn multiple video files on 1 dvd using ConvertXtoDVD
By sascha_ in forum Newbie / General discussionsReplies: 1Last Post: 31st Jan 2010, 07:09 -
Combine multiple FLV files in one flow.
By nevsky in forum Video Streaming DownloadingReplies: 0Last Post: 24th Jan 2009, 08:06 -
Convert multiple image files into one and burn onto DVD
By Mark97213 in forum Authoring (DVD)Replies: 1Last Post: 30th Jul 2007, 04:26
