  1. I've got some files with ac3 audio, I've got ffdshow as well as ac3filter installed but when I load the file in vdub, change the audio to full process mode and save the wav I get an error about no audio codec to decompress source tag 2000. I tried a direct enocde in tmpgenc but it didn't pick up the audio from the file so I have to extract it manually, I've also tried to change the direct show media filter thing up and down but that didn't do much. mm... yeah what to do or should I just extract it as ac3 instead of wav ? If so how?
    Dec 2004
    Australia
    If you want to decode with VDub, try fccHandler's AC3ACM.
  3. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Is your end product a video DVD?
    If so, just save audio direct stream. VDub will add wav headers and rename it to .wav, but just change the extension back to ac3 and run it thru ac3fix. Then use this ac3 when authoring your DVD.
    /Mats
  4. hmmm yeah i'm going to convert it as vcd then put it on the dvd so that I can fit more on the dvd, I managed to extract it as direct stream audo but not the full process, why is this ? And is it better to extra audio from an avi as direct or full ? I've always did it as full even tho it takes longer and way more space. For some reason tho I tmpgenc keeps quitting with no error msg during the encode.
  5. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Direct Stream works, where Full Process fails, because Direct stream just dumps the stream out, where FP tries to read the content of the stream, and process it.
    TMPGEnc can't handle AC3, so you'll have to convert the AC3 to wav before letting TMPGEnc touch it - try headac3he to that end.
    /Mats
  6. Thats right TMPGEnc will not handle AC3 as well as VBR audio in most cases. It is recommended to extract the audio and convert to desired specs. I would second HeadAC3he as suggested by mats. TO convert to 2ch AC3 use ffmpeg
    When I was born I was so shocked that I could'nt speak for 18 months.
