Anyone capture with this card yet? I'm looking for the best options for capturing NTSC SVCD video. Default options are:
Vid Compress 4.0Mbites/sec Rez 320x480 Aud Sampling 32KHz and Audio Compress Off
While waiting for a reply I started playing around with the settings and no matter what I did Nero would error out with "stream encoding not compatible". I use the CL Digital VCR which captures to *.bts files and than I use it's own file converter to get the *.mpg file.
So now I need help with the settings and the above problem, they may be related though. Thanks! -
I have been doing test with this card, i had bought it because i want to record some of my analog tapes to SVCD.
With the video there is no problem, but you have to keep the bitrate low... the max for svcd is 2.6 (audio + video)
i have set a bitrate of 1.5 Mbit/sec, resolution 480x480
The audio is the problem, SVCD only accept 44.1 Khz, you must convert the audio
follow this steps:
1.- demux with tmpeg
2.- encode the audio to 44.1 Khz (i use 160 Kbit/sec)
3.- remux with tmpeg
pd: i still do not understand why creative does not allow to capture the audio directly to 44.1 Khz, i hope the hardware can handle it -
I am thinking the pv 231/233 or 25x cards or the ads usb instant dvd device are the best out there for files to burn for dvd player use.
search for other posts for these cards before you buy.
Standard Cable w/o STB thru VCR will allow digital stations?
By rcholden in forum Newbie / General discussionsReplies: 3Last Post: 8th Nov 2009, 21:55 -
Comcast digital transport adapter question with vcr/dvdrecorder setup
By yoda313 in forum Off topicReplies: 4Last Post: 18th Jul 2009, 15:35 -
Help deciding on Hi8mm VCR or Digital 8 Camcorder
By k2skier in forum Newbie / General discussionsReplies: 8Last Post: 12th Dec 2008, 01:52 -
Converting digital off air tv streams for Creative Zen (Avi, MWV.....)
By naderro in forum DVB / IPTVReplies: 1Last Post: 17th Dec 2007, 19:27 -
Is anyone making good S-VHS VCR's anymore with digital filters?
By Wile_E in forum Newbie / General discussionsReplies: 3Last Post: 31st Oct 2007, 14:46
