Can someone please tell me how to predict the size of a kvcd file?
I have tried using this guide: http://kvcd.net/guides/kguide/kvcdguide.htm but I cant understand it because it looks like the author is using several different examples for his calculations (ex. he uses a file with 155413 frames then he uses a file with 208885, then he uses a file with 233505). A simple step by step guide using the same file throughout would be much appreciated.
I thought KVCD's were pure VBR? If so then you can't really predict the size. You could always do a 2 pass VBR encode, but with the KVCD notch quant matrix. That way any bitrate calculator will do.
Yes there is some way that they do it by encoding samples throughout the movie and take the file size and put that in a formula and you get the prediction size. It looks easy but when I do it I get this ridiculously large file, the author gets a 15.3mb sample file size using a file with 155413 frames, I get a 103mb sample file size using a file with 179898 frames.
Yeah I was just thinking that after posting.... Without running a bunch of compressibility tests. There are apps for doing this with CCE, HCEnc, etc. for 1 pass DVD encoding. No idea about KVCD.
179898 frames represents what percentage of your encode?
Hang on. 155,413/24 = 6,475 seconds/60 = 108mins. No way you are going to get 108mins at 15.3MB's. -
179898 is the number of frames in my original file
The author is somehow getting a 15.3mb sample file using a source file with 155413 frames. In his avisynth script is "Sample(100, length=24)", I use "SelectRangeEvery(100, length=24)". Do Sample() and SelectRangeEvery() do the same thing? If not, then that may be my problem. -
That would give you 0 to 23, 100 to 23, etc.
So if you get 103MB's then it means that your final should be around 430MB's. -
I used sampler(100, length=24) instead of SelectRangeEvery(100, length=24) and it predicts it within 2mb, wow.
If anyone is wanting to do this with avisynth 2.5 you need this sampler dll > http://www.incredible.de.tf/Downloads/Sampler-2.5.rar
prediction: "Bulldozer" will be a beast
By deadrats in forum ComputerReplies: 6Last Post: 3rd Oct 2011, 06:37 -
Removing Weighted Prediction in P-frames
By ad.vid in forum Blu-ray RippingReplies: 4Last Post: 29th Oct 2010, 12:18 -
KvCD to vob
By natty in forum Newbie / General discussionsReplies: 2Last Post: 19th Aug 2010, 15:37 -
MPG to KVCD HELP
By G33333 in forum Video ConversionReplies: 12Last Post: 25th Dec 2007, 06:00 -
KVCD
By Bat21UK in forum Authoring (DVD)Replies: 7Last Post: 22nd Dec 2007, 15:31
