I wasnt sure which section to post this in and Ive never attempted anything like this before. What I want to do is just capture a 2 minute scene from a DVD and then convert it to an .avi. Do i need to rip the entire dvd to my hard drive first or is there just a way to capture the scene I need? The only software I have at the moment is PowerDVD and Nero 6 and DVD shrink. Thank you for any and all help and hope I explained what I needed fully.
Results 1 to 10 of 10
You can use dvd shrink. Go to reauthor mode. Select the title you want. Then on the left panel theres a button with two parallel lines - click that and you can select just a chapter or adjust the slider to what you want.
Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
Thanks I'll try that, but first do i have to backup the entire dvd onto my hard drive?
cool I did that and got the section I needed. any tips on how to convert the vts file to an .avi?
??? Vts?? You should have gotten a vob file. Load the vob file into virtualdubmpeg2 and select the codec you want.
Youre right sorry, it is a VOB file but its labeled VTS_01_1. I downloaded and installed VirtualDub but when I open the vob file it says:
MPEG Import Filter: invalid pack position at 3: marker bit not set; possibly MPEG-2 stream...
Im not sure whats wrong and sorry if I'm a pain. -
No problem. Maybe what you should do is rip the whole chapter. It could be some kind of a read error.
Select the entire chapter and then after you can select just the section you need in virtualdubmepg2 to avi.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
It must be scratched up pretty badly then. Settop players can sometimes read bad discs better than ripping programs (error correction and a alot of stuff I don't know about).
You may be stuck with a bad disc. Is it homemade? Try using the original source again.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
How to capture gameplay from XBOX360 to AVERTV capture card
By Ollie999 in forum Capturing and VCRReplies: 2Last Post: 25th Oct 2011, 20:16 -
Exsate DV Capture Live: AVI / WMV Capture Settings?
By Obtong in forum Newbie / General discussionsReplies: 1Last Post: 8th Jul 2011, 11:42 -
Capture device needed for old VHS or 8mm camcorder capture....What to get?
By thor911 in forum Capturing and VCRReplies: 11Last Post: 5th Oct 2007, 04:31 -
Does simultaneous computer usage affect capture quality w/USB capture?
By miamicanes in forum Capturing and VCRReplies: 3Last Post: 19th Sep 2007, 18:05 -
Trying to capture Xbox 360 footage - Excellent Quality capture?
By Mysteriouskk in forum Capturing and VCRReplies: 5Last Post: 11th Jun 2007, 19:42
