I just bought a 530H but I have two minor problems.
Firstly on the Easy Timer feature, if I set a recording in the future it wont show up on the timeline so there is no way to edit, remove, or see if there are existing recordings scheduled. Is this suppose to happen?
Secondly does the 530H output on rf or does it only pass through what it gets from the rf input back out the antenna output E.g.
[RF INPUT] -> 530H -> [RF OUTPUT]
[CH1-5] -> 530H -> [CH1-5]
[CH1-5] -> 530H -> [CH1-5 + 530H current output]
*If I got channels 1-5 coming into the input rf connector on the 530H, would it only get 1-5 back out of the output rf connector or do I get channels 1-5 + 530H output.
The reason I ask is because I send the scart output to the TV, and then send the RF output around the house, so people in other rooms could see the 530H output along with terrestrial channels. At the moment it would seem that it doesnt output to rf - my current tv only picks up channels 1-5 coming from the 530H which is disappointing. Any ideas?
Thanks in advance
Can't help you with the first issue, but the answer to the second is that the Pioneer only passes through the RF signal. You must use the line connections to view what's playing from the Pioneer.
Ok thanks, I'll take one of the Line outputs and pass that to my VCR to get it on RF.
Easy Timer issue is annoying - got no idea if other people have recordings scheduled at a certain time. -
Just incase anyone has the same problem, I found the answer to the editing a scheduled recording.
It is found in the TV Guide, so even if you dont use the TV Guide, an Easy Timer recording is stored in the TV Guide Schedule List.
HDD Data Recovery - from Pioneer DVR-530H-S failed hard drive
By fortisMilvus in forum DVD & Blu-ray RecordersReplies: 17Last Post: 15th Feb 2025, 02:20 -
Pioneer DVR-530H. Unable to delete or edit some titles.
By Baloooo in forum DVD & Blu-ray RecordersReplies: 7Last Post: 20th Mar 2011, 00:15 -
problem remotecontrol pioneer 530H recorder
By voorhoek in forum DVD & Blu-ray RecordersReplies: 5Last Post: 28th Dec 2010, 19:21 -
Pioneer DVR-530H Question (Please help)
By Corey_Futurama in forum DVD & Blu-ray RecordersReplies: 7Last Post: 10th Jul 2010, 07:28 -
DVD writer exchange for my Pioneer DVR-530H
By J.J.F in forum Newbie / General discussionsReplies: 1Last Post: 20th Jan 2008, 09:40
