this is the guide:
How to add your own subtitle to DVD (keep menu, multi-episode, multi-pgc)
https://www.videohelp.com/forum/viewtopic.php?t=275603
I have a problem after remuxing the movie with MuxMan...
the process went good no errors, but when i played the movie to see if the subtitles are in sync... i disovered that the audio is out of sync :\
can anyone tell why? is there something i missed?
nope.
there is no delay... :\
i tried to multiplex the movie with MUXMAN, IfoEdit and ImagoMPEG-Muxer and got the same problem is the audio sync in all programs. -
Hi-
Then you'll have to find and correct the delay yourself. Unfortunately I don't know of any way to check it without reauthoring and playing it, and it may take 3 or 4 tries to get it right. Anyway, estimate the delay. It's done in milliseconds with 1000 ms=1 second. You set a negative delay if the sound currently occurs after the lips move, or the gun fires, and you'll want a positive delay if you hear the gun file before you see the flash. Using Muxman, you can only set a delay of up to 600 ms, I think. I forget what it is with IFOEdit. You can use AC3 Delay Corrector if it's greater than that.
How to add ".ass" subtitles to a ..."h264" file?
By Tatsubon in forum SubtitleReplies: 3Last Post: 20th Apr 2012, 18:35 -
Handbrake "Burned in" Subtitle Problem
By Roxas13 in forum SubtitleReplies: 0Last Post: 4th Apr 2012, 04:57 -
ConvertxtoDVD - Subtitle #2 (subtitle) etc Coodec Tag "mp4s" Unsupported
By Simmons in forum Video ConversionReplies: 0Last Post: 10th Jun 2011, 06:36 -
Tip: How to add "detele" and "up" buttons in Vista/7
By roma_turok in forum ComputerReplies: 1Last Post: 3rd Jul 2010, 14:54 -
How to get an "l"not an "I" when ripping the dvd subtitle to text format
By cairuitao123 in forum SubtitleReplies: 12Last Post: 24th Mar 2010, 20:50
