I have been using a Sony DVD burner for a couple of years now very successfully. However, the other day, I burned 2 movies using my usual Nero on Maxell +r DVDs. When I tried to play them, my DVD player returned a "DVD-r" error message and refused to play them. Has anyone encountered this error before? Could it be a mislabeling or QC problem with the DVD blanks? Half the spindle worked just fine.
Any help appreciated!
Brian
Your player is just giving out a default message that it cannot play this particular burned disc. It has nothing to do with DVD-R or DVD+R. The player is probably pre-DVD+R and just assumes any burn is DVD-R.
Thanks for the response. It's a pretty new player--a Toshiba HDMI upsampling unit that funnily enough is supposed to play DVD + and - r's. I suspect that you are right however, that there is some sort of fault in the burn. The disks play fine on my computer, however. I think I'll buy a new box of blanks and do some experimenting!
Thanks again,
Brian -
Toshiba ignores the world of DVD+R and DVD+RW even though most models play them equally as well as DVD-R and DVD-RW. Same for DVD+R DL, works fine.
They are a founding member of the DVD Forum, and therefore ignore anything unofficial (like all RW Alliance stuff).
Be sure you use good discs! See www.nomorecoasters.comWant my help? Ask here! (not via PM!)
Thank you for the excellent link and information; the page is a great resource.
Best,
Brian -
Here's a final follow-up. I downloaded the Sony drive test software and the drive failed the write test--bummer! However, Best Buy has the Pioneer DVR-R100 dual layer drive for $69.99 plus a $20 mail-in rebate. At $49.99, it's cheaper than the Best Buy house brand. The drive has a PC magazine Best Buy status. I bought it, installed it, and it works faultlessly. Normal service has been resumed!
Thanks for all the help and advice,
Brian
finalizing dvd after image has been written
By Down1oader in forum Authoring (DVD)Replies: 3Last Post: 1st Dec 2011, 17:10 -
DVD cannot be read after written - Pls Help
By its_me in forum DVD & Blu-ray WritersReplies: 6Last Post: 11th Jun 2008, 02:25 -
Written/burned DVD-R Question
By BrokenOne in forum DVD & Blu-ray WritersReplies: 3Last Post: 21st Apr 2008, 23:11 -
Sony written DVD not copying on PC
By Sainkho in forum DVD RippingReplies: 4Last Post: 12th Apr 2008, 22:21 -
Sony DW-Q28A can't read DVD+R written on itself
By mackayr in forum DVD & Blu-ray WritersReplies: 3Last Post: 5th May 2007, 18:31
